How to make a box cover?
xtremej
Gold - Posts: 1,440
Posted: April 05, 2006 at 11:28 AM / IP Logged
Another alteranitve for ya is truck bed liner. I've had a couple down in different colors, tough and looks pretty good.
austincustoms
Copper - Posts: 232
Posted: April 05, 2006 at 12:19 PM / IP Logged
It's really hard to get MDF painted and stay looking nice.  A better way, if you just want the face of the enclosure done is to paint the back side of a thin piece of clear plexiglass cutout to the shape you want to cover.  Put it paint side down, and use the subs or screws to hold it down.  This will give you a super high gloss finish.
extremej, do you have any pics with the different colors?  I would be interested in that.  And about what would a shop charge to spray a typical enclosure?
xtremej
Gold - Posts: 1,440
Posted: April 05, 2006 at 1:13 PM / IP Logged
I don't have any but the next one i do I will take some. The last one I had coated was done in red to match the truck, looked pretty cool.  It cost me $25 bucks. They were doing another pick up bed at the same time though. If you go this route make sure you take into account that this stuff is pretty thick I had to re-drill the holes for wiring to amp rack.. I am not sure but somebody told me you can order spray cans of colored bed liner, I am looking into that. If I find anything out I'll post it.
lukeyn
Member - Posts: 47
Posted: April 05, 2006 at 3:21 PM / IP Logged
I thought about the plexiglass idea, but the only thing is plexiglass is pretty hard to cut without cracking it. How did you go about cutting it so it didnt crack?
Thanks for all the replies everyone...
austincustoms
Copper - Posts: 232
Posted: April 06, 2006 at 12:38 AM / IP Logged
double stick tape it to the face of your eclosure before you attach it (if you are making it) or before you carpet it.  Using a router with a flush trim bit, cutout the shape of the face at a medium speed.  If you use a thick plastic [which isn't necessary unless you are making the face out of plastic, instead of just a cover] you may need to spray wd40 or liquid wrench on it as you cut.  Then peel it off, paint the back of it, and attach it paint side down.  If you don't have a router, you can use a rotozip or a dremmel with a rotozip crosscutting bit.  Set it on the lowest speed, and it should cut the plastic (slowly) and not the MDF.  I've got a picture around here somewhere,  I'll post it if I can find it.
lukeyn
Member - Posts: 47
Posted: April 10, 2006 at 12:23 PM / IP Logged
alright cant wait to see the pics
austincustoms
Copper - Posts: 232
Posted: April 11, 2006 at 8:52 PM / IP Logged
Hmmm, let's try this again.
This is a speaker enclosure I did with solid black plexiglass from selectproducts.com.  I'll keep looking for the painted one.
austincustoms
Copper - Posts: 232
Posted: April 11, 2006 at 9:02 PM / IP Logged
