amp wired
instalador
Member - Posts: 8
Posted: April 25, 2006 at 12:32 PM / IP Logged
hello guys. i will like to get all sugestion..im  / installing a amp( a 4chanel amp.
model brand( audiofonics digital max adf.242- 1100 wx .im installing on small toyota truck 96 tacoma .   i will use 2 chanel ( 1-2) for a componente  alpine in front doors .the speaker is a250 w.   .the other 2 chanel i will use for the  single woofer .selead box (kicker cvr 4 ohms.dvc.,what type of wire configuracion will be the best (paralel or  series) on speaker woofer 10 inch.dvc 4 omhs?
note;amp features,2omhs stereo/4omh mono  ----2-ohm stable(4ohm bridged------ odb-18bass boss with varble sub(45hzamp wired - Last Post -- posted image.
electriope88
geepherder
Platinum - Posts: 3,668
Posted: April 25, 2006 at 7:58 PM / IP Logged
I'd bridge the amp and wire the voice coils in series.  This is electrically the same as one voice coil per channel.
instalador
Member - Posts: 8
Posted: April 27, 2006 at 1:19 PM / IP Logged
thank you so much!!           geepherder.....
it help  a  lot .  series ( sounds  good)
electriope88
