Carpet under sub airtight?
luckydevil
Silver - Posts: 365
Posted: May 30, 2006 at 12:47 PM / IP Logged
I'm working on a new box and I was wondering if it matters whether or not there is carpet under the subwoofer lip when it is mounted.
I am thinking that the carpet may actually help to get an airtight seal, but then again bare wood is flat and could possibly give a better seal with a thin foam gasket.
I know this is pretty trivial, but I'm curious if one method is better or preferred over the other.
Thanks guys.
coppellstereo
Silver - Posts: 785
Posted: May 30, 2006 at 1:07 PM / IP Logged
I've never seen a box that mounted the drivers to bare wood.
DYohn
Platinum - Posts: 10,741
Posted: May 30, 2006 at 3:04 PM / IP Logged
Carpet under the subwoofer mounting flange?  No, carpet is not a good idea as it is definitely not air-tight.  Use foam weather strip, silicone sealant or caulk, or some of the special rubberized speaker mounting gaskets.
sab0276
Copper - Posts: 61
Posted: May 30, 2006 at 3:19 PM / IP Logged
So should you cut out some of the carpet so that the woofer mounts directly to wood?
-Scott
2002 GMC Yukon SLT non-Bose
Pioneer AVIC N3
Drewt
Copper - Posts: 183
Posted: May 30, 2006 at 6:50 PM / IP Logged
yes
I've used some weird removable weatherstripping for my previous subs (subs w/ rubber gaskets rock!!), it's a roll of 6-8 beads of weatherstripping. Wrap that around the sub, screw it in, let the excess seal squeeze out, then just peel it away.
good luck
boug0752
Copper - Posts: 73
Posted: May 30, 2006 at 8:41 PM / IP Logged
To be honost I haven't had any problems with air leakage through the area around the sub. Theoretically you should cut away the carpet and use some type of sealant but if its a ported box its most likely not going to be a problem.
If your counting pennies and dimes then maybe you shouldn't be spending every penny and dime you have!!
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
