8 or 10 subwoofers
bassreka
Member - Posts: 11
Posted: June 18, 2006 at 4:56 AM / IP Logged
I have a 89' Toyota Pickup & i have very little room for a speaker box, But i managed to fit four 8" Subwoofers 600watt max a piece being pushed by a 2000watt amp. The boxes are real small & it doesnt seem to be hitting very hard at all. Would it make a difference if i installed 2 x 10" 1100watt max subwoofers? If so how much?
jeffchilcott
Platinum - Posts: 2,483
Posted: June 18, 2006 at 7:32 AM / IP Logged
One single woofer can be made just as loud as multiple woofers.    approx how much space do you have total in cu ft or cu in.....or just demensions and we could make a better suggestion
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
jlord16
Silver - Posts: 322
Posted: June 18, 2006 at 8:07 AM / IP Logged
The box that they are in plays the majour part in how loud the subs can get, we need specs to help u out more
Clarion DB36MP
Infinity Kappa Perfect 10"
Respone 800w Mono
ALPINE MRP-F250
*Custom fabrications*
bassreka
Member - Posts: 11
Posted: June 18, 2006 at 8:28 AM / IP Logged
Well i fit 2 subs behind the seat & 2 under the dash board. Box dimensions: Height 9", Width 16 1/2", Depth 6 1/2"
aznboi3644
Gold - Posts: 2,600
Posted: June 18, 2006 at 10:19 AM / IP Logged
Are those dimensions internal or external?
Also what subs are these? amp?
mobilesndfx
Copper - Posts: 49
Posted: June 18, 2006 at 6:58 PM / IP Logged
I bought an '89 Toy lowrider back in '91. Tried many boxes including fiberglass, trying to get as much air space as possible. My final solution was to cut the metal between the bed and cab, mount the box in the bed firing in the cab. Air space and possibilities are unlimited at this point. Behind the seat of a standard Toyota is very slim, if you find som ething that works good without cutting metal out, let me know, I couldnt.
Alpine 9835, MB Quart components, (3) JL Audio 10w3v2, JL Audio 500/1, JL Audio 300/4, Streetwires wiring
DYohn
Platinum - Posts: 10,741
Posted: June 18, 2006 at 7:33 PM / IP Logged
Subwoofers located in different places inside the vehicle can result in cancellations and reduce the overall SPL.  Are all four of your enclosures 9 X 6.5 X 16.5?  If so, I agree with some of the suggestions above and say use the space now occupied by the two behind your seat and replace them with a good single 12" woofer, and dump the two under your dash.
supradude
Silver - Posts: 915
Posted: June 19, 2006 at 4:46 PM / IP Logged
I've put two 10's in that type of truck before and they hit great. Or like Dyohn said, one 12 will work. You'll have to get creative with the box or if you don't have much experience building them you might want to get a shop to build one for you. Just make sure they know what they're doing.
'85 Toy
