Urgently need 07 Escalade Wiring diagrams
escalade007
Member - Posts: 6
Posted: June 20, 2006 at 7:50 PM / IP Logged
Hi, I've been unable to locate any 07 Escalade electrical wiring diagrams. Can someone tell me where these are available from?
Also, does anyone know where the starter/kill wire switch is?
chungo
Copper - Posts: 135
Posted: June 20, 2006 at 8:32 PM / IP Logged
12voltsRED / white (2A) + ignition harness
Notes: For high current 12V, use RED / black (60A) and RED / black (60A) at the fuse box, black 40 pin plug, pins F1 and E3, or go to the battery.
Starterwhite + ign harn or BCM, lt. grn plug, pin 4
Notes: Starter is positive trigger thru a 1300 ohm resistor.
The BCM (Body Control Module) is to the left of the steering column.
See DirectFax document 1605 for remote start interface information.
Second StarterN/A
Ignitionpink + ign harn or BCM, lt. grn plg, pin 14
Notes: The BCM (Body Control Module) is to the left of the steering column.
Second IgnitionN/A
Third IgnitionN/A
Accessorybrown + ign harn or BCM, lt. grn plg, pin 21
Second AccessoryN/A
Keysensepink + ign harn or BCM, lt. grn plug, pin 2
Power Locksee notes
Notes: To lock/unlock the driver door go to the driver door module or motor in the door and 5wi the tan (lock) and purple (unlock) motor wires.
To lock/unlock the passenger door go to the passenger door module or motor in the door and 5wi the tan (lock) and gray/black (unlock) motor wires.
To lock/unlock the rear doors use lt. blue (+) and white (-) at the BCM, gray plug, pins 7 and 9.
Power Unlocksee power lock notes
Lock Motorgray 5wifuse box, black 14 pin plug, pin B4
Unlock Motorpurple 5wiDDM, brown 16 pin plug, pin 8
Notes: The DDM (Driver Door Module) is in the driver door.
Parking Lights+brown (L), brown (R) + underhood fuse box, blk 30 pin plug
Parking Lights-lt. blue - switch or BCM, natural plug, pin 8
Hazardswhite - switch or BCM, lt. grn plug, pin 19
Turn Signal(L)lt. blue/wht (F), yel/blk (R) + BCM, brown plug, pins 4 and 1
Turn Signal(R)dk blu/wht (F), dk grn/wht (R) + BCM, blk plg, pin 5; brn plg, pin 2
Reverse Lightdk. blue + BCM, natural plug, pin 22
Door Triggersee notes - see notes
Notes: The LF door is gray/black at the DDM, brown 16 pin plug, pin 13. The RF door is BLACK/ white at the PDM, brown 16 pin plug, pin 13. The LR door is lt. blue/black at the BCM, pink plug, pin 15. The RR door is lt. GREEN/ black at the BCM, pink plug, pin 14. Use all four wires and diode isolate each.
The PDM (Passenger Door Module) is in the passenger door.
Dome Supervisiongray + BCM, natural plug, pin 5
Trunk/Hatch Pinpink/black - BCM, pink plug, pin 12
Hood Pinpink/black - pin sw or BCM, black plug, pin 17
Trunk/Hatch Releasepink (glass), gray (gate) - BCM, pink plug, pins 24 and 13
Notes: Meter these wires while opening the liftglass or liftgate from the handle on the rear liftgate.
On vehicles with the power liftgate, use dk. GREEN / WHITE (-) at the switch in the overhead console.
Power Sliding DoorN/A
Factory Alarm Arm
Factory Alarm Disarmlt. green - DDM, brown 16 pin plug, pin 4
Notes: Meter this wire while turning the key in the driver door key cylinder.
Disarm No Unlockwith ignition and Passkey
TachometerNOT pink, brown, or black ac any ignition coil or fuel injector
Wait to startN/A
Brake Wirelt. blue/white + switch or BCM, brown plug, pin 6
Notes: Meter this wire while pressing the brake pedal with the ignition on.
Parking Brakelt. blue - switch or BCM, brown plug, pin 16
Horn Triggertan - switch or BCM, brown plug, pin 18
Memory Seat 1orange + switch or DDM, blk 26 pin plg, pin 5
Notes: Memory seat 1 is positive trigger thru a 2260 ohm resistor. Memory seat 2 is positive trigger thru a 4260 ohm resistor.
Memory Seat 2same as memory seat 1 wire +
Memory Seat 3N/A +
Urgently need 07 Escalade Wiring diagrams - Last Post -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
PASS-Key III+
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Standard on all models.
Smart Starter Kill Relays:Relay Type:
Starter Relay
Engine compartment fusebox, Driver side
Part #: 6404A
escalade007
Member - Posts: 6
Posted: June 20, 2006 at 9:45 PM / IP Logged
Does a schematic exist of the electrical?
integratyper934
Copper - Posts: 150
Posted: June 20, 2006 at 10:24 PM / IP Logged
the car runs on a lan system what exactly are you trying to do i heard some things about if you disconnect the radio youll have some problems. i know the factory overhead cant be used with an aftermarket head unit. what are u trying to accomplish?
escalade007
Member - Posts: 6
Posted: June 21, 2006 at 2:33 PM / IP Logged
I'm trying to obtain information as to how to hook up equipment to it. One local dealer has given a story that he needs electrical schematics as he can't find the starter/kill switch to hook up a gps locator such as thewitness.net.
integratyper934
Copper - Posts: 150
Posted: June 21, 2006 at 2:50 PM / IP Logged
a dealer needs schematics??? what is it a contacted lo jack installer or soemthing
escalade007
Member - Posts: 6
Posted: June 21, 2006 at 3:05 PM / IP Logged
If you visit the website it gives you all the details. It's more advanced the lojack. You're supposed to be able to disable the car from starting via the gps.
All I know is I've heard a bunch of excuses that the escalade is very electric and complicated.
bdl666
Silver - Posts: 330
Posted: June 21, 2006 at 4:27 PM / IP Logged
This is what chungo posted.  Just in its original form so you can print it.
http://directechs.com/directwire/print.asp?action=select&yr=6216&product=Remote%20Start
ieSpell rocks.
escalade007
Member - Posts: 6
Posted: June 22, 2006 at 11:20 PM / IP Logged
Here's a good question. My dealer is trying to install the viper in the 07 escalade. Since the control module that controls door locks etc is not avail. for another 60-90 days for 07 model according to directed and 06 model won't work, he hard wired each of the door locks. Only the passenger door locks seem to work. Anyone have thoughts as to why?
escalade007
Member - Posts: 6
Posted: June 23, 2006 at 10:23 PM / IP Logged
Problem solved.. only have to wait for a module for kill/starter to come out.
Tuesday, July 1, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
