Line Driver
mtmas8
Member - Posts: 17
Posted: July 19, 2006 at 1:57 PM / IP Logged
My headunit+signal processor currently is giving out a 4V pre-amp output and i was looking into purchasing a line driver which claims to give a 10v preamp output. will this work out if my subs are on a 10v preamp and my components are on a 4v preamp or should i hae the both the same, also i would be powering 1000/1 jl audo mono amp with 10v's will that be able to handle it?
Alpine D310 HeadUnit
Alpine PHX-H701 Signal Processor
(2) JL 13W7 Subs
(2) JL 1000/1 Amps
DYohn
Platinum - Posts: 10,741
Posted: July 19, 2006 at 3:35 PM / IP Logged
It won't matter at all as long as you set each amplifier's gain properly.
dwarren
Posted: July 19, 2006 at 4:06 PM / IP Logged
How about the good old question, why do you feel you need one? More devices in the signal path offer more chances for the introduction of noise.
jeffchilcott
Platinum - Posts: 2,483
Posted: July 19, 2006 at 5:39 PM / IP Logged
not sure on the JL's but I know almost all product will not take much more then 5-6v input.    The high end eclipse amps will take up to 8v   but I havent seen much besides that
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
