Running Correct Power To My Sub
spg
Posted: July 22, 2006 at 3:23 PM / IP Logged
I have a Kenwood 12V 1000W amp and its running to a sony 12" Xplode Sub...  I know that this amp is alot of power to run to a 12" sub and I want to make sure i dont blow it by running too much power to it.  I dont want to turn it down too much though.  How should i set my amp so its safe from blowing the sub but i still get a good sound?  Right now  i have things set like so:
Bass Boost is at 6dB
Expander is ON
low pass is ON
lpf frequency (Hz) is set at 70  (min is 50, max is 200)
Input sensitivity (V) is set at 2 (min is 5, max is 0.2
Sub is bridged.
Head is a sony Xplode unit.
What should i do different?
Also they give you a black ground wire to run from the sub to the head.  Is it really necessary to run this wire?
I appreciate any input here, thanks.
aznboi3644
Gold - Posts: 2,600
Posted: July 22, 2006 at 8:58 PM / IP Logged
do a search on how to set your gains
stevdart
Platinum - Posts: 5,816
Posted: July 23, 2006 at 9:57 AM / IP Logged
Setting bass boost on, especially as high as +6 db, means that the amplifier is supplying power to that narrow bandrange at four times what it is supplying to the rest of the subfrequency spectrum.  I recommend you leave it off altogether and set up your system without it.
