Progressive unlocking, Hornet 742T
dbd5000
Posted: July 31, 2006 at 11:28 AM / IP Logged
Vehicle - 1998 Ford F150
I have installed the DEI Hornet 742T. Everything is working fine except the manual talks about progressive unlocking (drivers door first than passenger door with a second push of disarm button). The subject shows up under installation options, but does not give any further how-to. Right now they both unlock at the same time. I have cut the pink / YELLOW (power lock) and pink/green (power unlock) and attached the alarm wires for a type C (reversing polarity system) as per the installation guide.
Can this function be accomplished within the unit by changing wires or is it something I need to add a relay for?
Thanks in advance for any input.
dbd
KarTuneMan
Platinum - Posts: 7,056
Posted: July 31, 2006 at 12:13 PM / IP Logged
Does the unit have a "second unlock"  or a "drivers priority" unlock youll need 3 relays one for unlocking the drivers door, one for unlocking the pass. door, and one for locking ALL doors.Check the install manual for a "different" unlock wire. I am NOT a DEI guy, so I do not know off the top of my pea brain. I did some reading, your unit has built in lock relays, thats too bad. Look at one of the 3 aux. outputs see if one of those could be used as a second unlock trigger. I read some more, and it does say in the owners manual Progressive unlocking is an option.....so ther MUST be a seperate trigger for priority unlocking....
dbd5000
Posted: July 31, 2006 at 1:12 PM / IP Logged
Thanks for the reply
After further looking I found this in the install manual.
If the pic did not come out correctly it says there is (-) second unlock wire.
Progressive unlocking, Hornet 742T - Last Post -- posted image.
I am not real sure what to do with H3/1 (blue wire). I am assuming I need to run it over the passenger kick panel and cut the unlock wire and attach it there.
dbd
dbd5000
Posted: July 31, 2006 at 1:14 PM / IP Logged
wow
Sorry
That didn't work - can it be deleted?
dbd
swamprat323
Gold - Posts: 1,335
Posted: July 31, 2006 at 11:11 PM / IP Logged
look at page 19 in th einstall guide   aux harness has a 2nd unlock wire
