07 Avalanche Avic-Z1 Problems
necrodreamer
Posted: August 10, 2006 at 11:25 PM / IP Logged
Ok, installed a good many headunits in my past... so I decided to tackle my 2007 avalanche with a Pioneer Avic Z1.  I have the new Metra Lan-02 adaptor to retain onstar and chimes.
Well, I am on day 2... still not working.  Last night, It started raining and I couldnt troubleshoot any further.   :(    If I put the key in the ignition, turn it one notch audio is on and chimes are chiming away because of my door being open.  Great... as planned.  I hit onstar button, works perfect.  XM, Ipod, etc.
Here's the kicker.... as SOON as I turn my key another notch (on the very edge of starting) or start the truck, OR close the door... audio goes away!  Headunit never hitches, xm still rolling, or ipod, or cd... but audio goes away.  I turn the key BACK a notch... whamo!  audio!.  I know you would think that this would be a simple wiring issue... me too.  So, I knew after work today I would come home and finish her right up.  NOPE, I have cut, recrimped doublechecked... everything!  Now, I am not saying it is not a wiring issue, it definitely probably is.  I just dont know enough about the acc and engine start process to know what wires would be the first to look at. ACC?  12v?  Ground?
I am mentally drained with this... can someone give some advice?
josh1979
Silver - Posts: 320
Posted: August 10, 2006 at 11:48 PM / IP Logged
call metra tech http://www.metraonline.com/contact.php
bring back the rotary phone so i dont have to press 1 to proceed in english
forbidden
Platinum - Posts: 5,354
Posted: August 11, 2006 at 12:10 AM / IP Logged
Start by metering the reg IGN line on the headunit when the vehicle is running.
Ctoh
Copper - Posts: 123
Posted: August 12, 2006 at 9:42 AM / IP Logged
I think you have a bad LAN-02 piece, I did two of these this week and had no problems,,,,they were in Suburbans but should be the same for the avalanche,,,,
StealthEs
Copper - Posts: 326
Posted: August 18, 2006 at 11:05 PM / IP Logged
Even if you leave the key in the ACC position but close the door the audio dies?
Cris
