New system
mako313
Posted: September 15, 2006 at 5:04 AM / IP Logged
I am new to these forums so please be gentle.
Currently I am running a Pinoneer 6800 head, MTX TC4004 amp and 2 12" Blitz audio subs.  In my '05 Chevy Silverado.
I want to run 2 Kicker L78's with the MTX amp, but I would really like to run 2 MTX amps to power the subs.
(i.e. Amp->Amp->Subs)
My question is how can/should I wire this setup.  I am not new to the whole audio install, but to the dual amp setup I am.  Any help would gladly be appreciated.
Ok, so maybe I'm not the brightest crayon...
haemphyst
Platinum - Posts: 5,059
Posted: September 15, 2006 at 6:39 AM / IP Logged
It's not difficult at all. Run a primary power cable to the back with a fused distribution block, and power the amps individually.
Signal from the deck to amp number one, a pair of RCAs from that amp to the next amp.
Now, connect each woofer to one amp. Done.
Your instruction manual will tell you which RCA jacks to use, but it won't be difficult at all. If you've installed one amp, you've installed 50. The only difference is tuning after the fact. Don't let it scare you off New system - Last Post -- posted image.
Flakman
Copper - Posts: 365
Posted: September 15, 2006 at 10:13 AM / IP Logged
Pass through is pass through...not sure how the strapping works though since if you are using the same inputs as normal, you would have to adjust for the proper gain on all subsequent amplifiers. Find instructions and read, then re-read.
The Flakman
I feel strange. I have deja vu and amnesia at the same time.
John | Manteca, CA
mako313
Posted: September 15, 2006 at 2:57 PM / IP Logged
Ok thanks a lot guys, I'll try that out see how it goes.
