LED wiring into 12v switch
devile
Member - Posts: 45
Posted: October 02, 2006 at 11:55 AM / IP Logged
Ok i have a single blue LED that i want to use as a light that turn on when i turn the switch on indicating that the thing the switch is controlling is on. Now can i just run a positive to one side of teh led and a negative to the otherside or will that kill the led... Please let me know what i need to do... Thanks
Big Dog
Gold - Posts: 1,265
Posted: October 02, 2006 at 12:24 PM / IP Logged
You need to add a resistor in series. The value depends on what are your LED's voltage and current requirements.
Take a look at this https://www.the12volt.com/installbay/forum_posts.asp?tid=81477&PN=2
Prepare your future. It wasn't the lack of stones that killed the stone age.
silverado42000
Copper - Posts: 65
Posted: October 02, 2006 at 12:29 PM / IP Logged
you need to put a resistor on the LED 470 Ohm, not thats if the blue LED uses 3.5V and 20milliamps
LED wiring into 12v switch - Last Post -- posted image.
