2006 Honda Pilot Keysense, Tips?
jetranger
Posted: December 11, 2006 at 11:36 AM / IP Logged
Guys ,
thanks for helping out with this. I just did an 07 Pilot and according to the data sheets from 05 (all i had) the factory arm/disarm is in the drivers door. THIS IS WRONG! As you stated, in the 06/07 Pilot the light green connector in the passanger side fusebox has 2 missing pins(probably pins #3 and #7).  I picked up a "spare pin kit for Chrysler products" at AutoZone and used 2 of the small pins in the kit and they worked out great. I soldered short wires to the pins, unplugged the light green, pushed the pins in and set them in place so they would connect to the factor spades in the fuse box. Plugged the connector back into the fusebox and it worked perfectly.  I spent 3 days trying to find the factory arm/disarm becuase i had bad information. Love the 2WFM900AS. so much better remote than Viper. You get what you pay for.
lsondubz
Copper - Posts: 193
Posted: January 26, 2007 at 11:01 AM / IP Logged
The customer came back and stated that they are having the domelight problem...What do I need to hook up to for this? Should I just run the status output wire to the keysense wire?
profuse007
Gold - Posts: 2,015
Posted: January 26, 2007 at 11:19 AM / IP Logged
do it like Chris Luongo (is this the real Chris Luongo?) said, autolock/unlock(ign locking control) before and after key insert.
Houston,TX
ihkili18
Copper - Posts: 108
Posted: January 26, 2007 at 10:12 PM / IP Logged
but if he ran the status output to the keysense, would that work as well?
lsondubz
Copper - Posts: 193
Posted: January 27, 2007 at 11:34 AM / IP Logged
The prestige unit does not have auto locks  I am thinking diode isolate the status out wire to the keysense wire should do it
Thursday, July 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
