doorlocks on 06 dodge charger
opy1095
Member - Posts: 48
Posted: November 10, 2006 at 11:49 AM / IP Logged
does anyone kno if i need relays for the doorlocks for this car?
Hymer
Silver - Posts: 695
Posted: November 10, 2006 at 12:59 PM / IP Logged
Only if your rs unit doesn't have them built in.. need resistors though....
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
Twelvoltz
Platinum - Posts: 2,384
Posted: November 10, 2006 at 2:02 PM / IP Logged
Here is what DEI lists for the Charger
DIRECTWIRE™ WIRING INFORMATION - DODGE / CHARGER / 2006 / Remote Start
[PRINT THIS PAGE]
12volts      lt. blue/red (15A)       +       ignition harness
Starter      pink/dk. green       +       ignition harness
Second Starter      PURPLE / brown       -       ignition harness
Notes: The second starter wire is negative trigger thru an 180 ohm resistor. MUST use a relay. Refer to DirectFax document 1084 for wiring information.
Ignition      pink/white       +       ignition harness
Second Ignition
Third Ignition
Accessory      same as second starter wire       -       ignition harness
Notes: The accessory wire is negative trigger thru a 610 ohm resistor. MUST use a relay. Refer to DirectFax document 1084 for wiring information.
Second Accessory
Keysense
Power Lock      PURPLE / dk. green       -       DKP or cluster, gry 26P plug, pin 5
Notes: Lock is negative trigger thru a 330 ohm resistor. Unlock is negative trigger thru a 100 ohm resistor. MUST use relays.
Power Unlock      same as power lock wire
Lock Motor      lt. green       5wi      DKP or cluster, gry 26P plug, pin 12
Unlock Motor      tan/lt. green       5wi      DKP or cluster, gry 26P plug, pin 11
Parking Lights+      WHITE/ purple       +       pass. kick, brn 26 pin plug, pin 26
Parking Lights-      WHITE/ brown       -       sw or cluster, gry 26P plug, pin 3
Notes: Parking lights are negative trigger thru an 1,670 ohm resistor. There is a rest resistance on the wire, so must use a relay to isolate from the switch.
Hazards      WHITE/ dk. blue       -       hazard switch
Turn Signal(L)      use hazards wire
Turn Signal(R)      use hazards wire
Reverse Light      WHITE/ lt. green       +       pass. kick, brn 26 pin plug, pin 17
Door Trigger      see notes       -       each kick or instrument cluster
Notes: The LF door is purple in the white plug, pin 3. The RF door is PURPLE / white in the white plug, pin 16. The LR door is PURPLE / gray in the gray 26 pin plug, pin 10. The RR door is purple / YELLOW in the gray 26 pin plug, pin 9. Use all four wires and diode isolate each.
Dome Supervision      yellow/white       +       instrument cluster, wht plug, pin 12
Notes: Also found in the passenger side A pillar.
Trunk/Hatch Pin      PURPLE / orange       -       PKP or cluster, gry 26P plug, pin 23
Hood Pin      PURPLE / lt. blue (export only)       -       pin switch under hood
Trunk/Hatch Release      PURPLE / tan       -       sw or cluster, gry 26P plug, pin 22
Notes: The trunk release motor wire is tan / YELLOW (5wi) in the passenger kick or instrument cluster, white plug, pin 24.
Power Sliding Door      N/A
Factory Alarm Arm      arms on lock with door open
Factory Alarm Disarm      factory remote only
Disarm No Unlock      with ignition and Sentry Key
Tachometer      NOT BROWN / yellow       ac       any ignition coil or fuel injector
Wait to start      N/A
Brake Wire      dk. GREEN / WHITE       +       brake pedal switch
Parking Brake      gray/black       -       sw or cluster, gry 26P plug, pin 18
Horn Trigger      dk. GREEN/ orange       +       horns under hood
Memory Seat 1      PURPLE / brown       -       memory switch in driver door
Notes: Memory seats are negative trigger thru resistors. The resistor values are not known at this time. Cut the wire and meter the values as you press the memory 1 and memory 2 buttons.
Memory Seat 2      same as memory seat 1 wire       -
Memory Seat 3      N/A       -
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Sentry Key
Part #: 556CW
Alternate Part1 #: DesignTech 29402
Alternate Part2 #: 556UW
Alternate Part3 #: DesignTech 20402
Notes: Standard on all models.
Door Lock Interface      Required:
No      Type:
Multiplex
Part #: 456LW
Notes:
Combo Interface      Required:
No      Type:
Data Bus
Part #: IOM-Chrysler-7
Notes:
Smart Starter Kill Relays:      Relay Type:
Starter Relay      Location:
Engine compartment fusebox, Driver side
Part #: 6401A
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
This car has a unique second starter/accessory wire that requires a little more than a normal vehicle (although becoming standard on chrysler). I would recommend picking up this, this piece does door locks, Trunk release, horn honk, and arm/disarm of factory alarm.
Sunday, June 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
