Electrically, what causes a fuse to melt?
coppellstereo
Silver - Posts: 785
Posted: November 18, 2006 at 9:44 PM / IP Logged
Electrically - what causes a fuse to melt instead of break.
I've heard it is loose connections, which to me, would be adding resistance to the circuit ... correct?
I assume the circuit is just dissipating extra heat, but not extra current ... is this right?
haemphyst
Platinum - Posts: 5,059
Posted: November 18, 2006 at 10:37 PM / IP Logged
The element in a fuse is just a wire... same as the 4 gauge wire it is protecting. It is a smaller gauge of wire, sure, but of a known melting point and resistance. This is why the elements in fuses are all different size, and the smaller the wire, the higher the temperature for a given amount of current running through it.
A 100A fuse, for example might offer a resistance of .033 ohms, but at 100A running through it, that is a dissipation of 3.3 watts. 3.3 watts with no heatsink, in a glass tube, with no air convection, and it will eventually get hot enough to melt...
That's pretty much it, really...
coppellstereo
Silver - Posts: 785
Posted: November 19, 2006 at 12:05 AM / IP Logged
I gotcha.
I've seen whole fuseholders melt, could something this simple cause it? Customers always ask me why, and I cant come up with the best reason. They always just assume they should up their fuse size.
coppellstereo
Silver - Posts: 785
Posted: November 19, 2006 at 12:33 AM / IP Logged
If the circuit's resistance doubles, it can only carry half the power, right? so is the other half of the power dissipated as heat?
aznboi3644
Gold - Posts: 2,600
um...they melt because most these days are made of crappy plastic that melts...If you get a man's fuse holder like this the holder wouldn't even break a sweat lol
http://www.bluesea.com/product.asp?Product_Id=23471&d_Id=&l1=&l2=
coppellstereo
Silver - Posts: 785
Posted: November 19, 2006 at 12:46 AM / IP Logged
ive never seen an ANL fuse holder melt, ive only seen the agu and maxi fuses/holders melt.
aznboi3644
Gold - Posts: 2,600
Posted: November 19, 2006 at 1:18 AM / IP Logged
I've need my friends fuse holder melt...woulda burned to hell but he noticed smoke coming from his hood...burned a ridge in his air filter box too lol
