daytime running lights not working
brhaugen
Copper - Posts: 275
Posted: November 22, 2006 at 9:11 AM / IP Logged
I installed an Prestige asp905 in a 97 Chev Blazer with daytime runnig lights.  Now the DTRLs are not working.  I used the internal relay (white wires) to switch between the Red (12v) and the Brown at the Headlight Switch.  What did I do wrong?  Should have I used another 12v source?
Big Dog
Gold - Posts: 1,265
Posted: November 22, 2006 at 9:33 AM / IP Logged
Make sure e-brake is completely released....a single click can render the DRL inop. Temporarily disconnect e-brake wire then start with key and see.
Prepare your future. It wasn't the lack of stones that killed the stone age.
brhaugen
Copper - Posts: 275
Posted: November 22, 2006 at 10:31 AM / IP Logged
Wow, okay, I beleve you but... the logic of turning off DRLs with the e-brake escapes me.
I will deffinatly try it when I see the vehicle over the holiday weekend... I did remove the release cable when I took the lower dash pannel off.
Thanks for your help.
Chris Luongo
Platinum - Posts: 3,746
Posted: November 22, 2006 at 1:12 PM / IP Logged
On many/most GM cars, applying the parking brake before turning the ignition on, will keep the daytime running lights from coming on.
Therefore, if the customer has forgotton to release the brake (or you forgot to reattach the cable), the DRLs won't work.
Also, nothing wrong with the way you wired up the parking lights with the APS-905. It would have saved a little time to just jump one of your white wires onto one of the thick red constant-power wires on the remote starter.....but your method is fine as well.
Seeg
Posted: November 24, 2006 at 4:17 PM / IP Logged
Hook up status output directly to the parking brake wire, this will resolve your issue.
cntrylvr79
Silver - Posts: 582
Posted: November 25, 2006 at 11:01 PM / IP Logged
Not really.  Doing that will turn off the drl when the truck is remote started.  He's having a problem with the drls working at all.
Cause I'm So white and nerdy...
First Class Certi-fried installer
