2002 honda accord coupe wiring
Welcome Guest :)
almeida79
Member -
Posted: December 02, 2006 at 8:11 AM / IP Logged
Hi I need a wiring diagram for a 2002 honda accord coupe for a remote start . Any help will gladly be appreciated . Thank's Jason
Jay
Mike M2
Platinum -
Posted: December 02, 2006 at 8:53 AM / IP Logged
12volts | white | + | ignition harness |
Starter | BLACK/ white | + | ignition harness |
Notes: If doing starter kill, must interrupt the wire between the keyswitch and the fusebox, not between the fusebox and the starter, to keep the check engine light from coming on. |
Second Starter | N/A | | |
Ignition | BLACK / YELLOW | + | ignition harness |
Second Ignition | N/A | | |
Third Ignition | N/A | | |
Accessory | yellow | + | ignition harness |
Second Accessory | WHITE/ black | + | ignition harness |
Keysense | | | |
Power Lock | BLACK/ blue | - | passenger side fuse box |
Notes: in a green 20 pin connector. Use BLACK/ white for lock and GREEN/ red for unlock on LX models without factory security. These wires are located in a two pin gray connector by the front of the drivers side fuse box. |
Power Unlock | orange | - | passenger side fuse box |
Notes: in a green 20 pin connector.Use BLACK/ white for lock and GREEN/ red for unlock on LX models without factory security. These wires are located in a two pin gray connector by the front of the drivers side fuse box. |
Lock Motor | WHITE/ red | | driver side fuse box |
Unlock Motor | | | driver side fuse box |
Notes: yellow on the EX and lt. GREEN/ red on the LX |
Parking Lights+ | RED / black | | driver side fuse box |
Parking Lights- | RED / yellow | | steering column |
Notes: Only available on the EX model. |
Hazards | | | |
Turn Signal(L) | | | |
Turn Signal(R) | | | |
Reverse Light | GREEN/ black | + | driver side fuse box |
Door Trigger | BLACK/ white | - | passenger side fuse box |
Notes: In a green 4 pin connector. |
Dome Supervision | use door trigger | | |
Trunk/Hatch Pin | orange | - | drivers kick panel |
Notes: Above the hood release in a gray 18 pin connector. On the DX & LX models, also found in a 2 pin connector behind the drivers fuse box. |
Hood Pin | yellow/red or yellow | - | hood pin switch or |
Notes: On the EX models it is in a green plug next to the passenger side fuse box. On the LX models it is at the keyless/security unit, if equipped, which is attached to the driver side underdash panel. |
Trunk/Hatch Release | WHITE/ red | + | drivers kick panel |
Power Sliding Door | | | |
Factory Alarm Arm | | | |
Notes: Arms and disarms with the door locks on the EX models. The LX models arm only with the factory transmitter. |
Factory Alarm Disarm | | | |
Disarm No Unlock | blue | - | |
Notes: On the EX the wire is located at the drivers power window switch, on the LX the wire is at the keyless/security unit which is attached to the drivers underdash panel. |
Tachometer | blue | | tach test connector |
Notes: The tach test connector is located behind the battery on the 4 cylinder, and on a bracket attached to the drivers side strut tower on the 6 cylinder motor. The tach test connector is a white 2 pin connector, and may be covered by a black rubber boot. |
Wait to start | | | |
Brake Wire | WHITE/ black | + | brake pedal switch |
Parking Brake | | | |
Horn Trigger | lt. GREEN/ blue | - | steering column |
Memory Seat 1 | | | |
Memory Seat 2 | | | |
Memory Seat 3 | | | |
Interface Module: | Category:Immobilizer Bypass | Required:Yes | Type:Transponder |
Part #: 1100F |
Alternate Part1 #: 1100X |
Alternate Part2 #: 556HW |
Alternate Part3 #: 556UW |
Alternate Part4 #: DesignTech 20402 |
Alternate Part5 #: DesignTech 29402 |
Notes: When using the 1100F or 1100X, a software change to 1100HA is needed. |
Interface Module: | Category:Door Lock Interface | Required:No | Type:Data Bus |
Part #: IM-Honda-2 |
Mike M2
Tech Manager
CS Dealer Services
Saturday, June 15, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
