Cold Cathodes
hotmilk400
Copper - Posts: 55
Posted: January 15, 2007 at 8:39 AM / IP Logged
you dont need a relay .. my 14 cathodes only draw like 1 amp (they are only 1.5 watts each)  its the same almost as a floresent light.. they take next to nothing to run.. yeah..all i did was pull the power from my cig lighter (but i got way to much on it now, i have to pull form the battery) .. haha..i got my car alarm, my sub and amp, and all those light on that cig lighter circuit...  one day im going to have to put that on my battery.. but its like 10 degreese outside.. haha.. and i dont wanna freeze..
mbaudio06
Copper - Posts: 60
Posted: January 19, 2007 at 12:02 PM / IP Logged
bellsracer wrote:
Very not bad... However I am SO jealous of you...
A Memphis 8 for only $30... Hook me up!
Memphis 8? Nowhere near a mephis, how about MA Audio
hotmilk400
Copper - Posts: 55
Posted: January 27, 2007 at 2:16 PM / IP Logged
some people have been asking me about how you go about hooking these lights up.. i bought them from a computer store, that had a 4 pin connector on the end... i simply cut that, and the small switch off .. and used the Red wire as the 12V + and the black wire as the 12V - .. if u still want to use the switch, or connector.. see where the red one changes colors after the switch, and use that wire (i think it turns yellow right? that is your knew 12V + ..
Cold Cathodes - Page 2 - Last Post -- posted image.
hotmilk400
Copper - Posts: 55
Posted: January 27, 2007 at 2:24 PM / IP Logged
for the wiring.  i have a 4gauge wire that comes right off my battery and goes to the back of my car for the amp.  i spliced into that wire for my 12V+ .. then for the 12V- i ran those wires back to my dash.. and under my radio, i have 2 switchs... one switch controls all those lights, and the other, my underbody kit.  i made it that the ground is on the switch just so i didnt have to ground those lights in like 10 spots..
and as a update, i just boungt some LED lights off a website, and i will replace the one light in my trunk (one u can not see in the picture) with LED lights.. i also bought UV LED lights for my headlights, and inside my engine area.   2 blue switchs to replace my Red ones(becasue the new radio i have interfears with the switchs.. )
firelizard
Copper - Posts: 54
Posted: February 09, 2007 at 1:49 AM / IP Logged
What fuse is recommended for this?
I did the same thing right after reading this thread - bought the 2 12" blue CCs from Xoxide and they got here this week.
Figuring out the Molex was simple.
Yellow from the male plug is 12v positive, black are grounds (duh).
Red one from the plug is for 5v
brentfullstop
Posted: February 09, 2007 at 5:25 AM / IP Logged
I have also just bought 2 cathodes and a switch, and i was planning on just fusing a wire from the battery, into my dash to power them. nice and simple - Battery -> switch -> cathode -> ground.   Is that all i need to worry about? or am i missing some crucial step here?
bellsracer
Silver - Posts: 703
Posted: February 18, 2007 at 11:40 PM / IP Logged
ROFL! >.< I guess that will be the last time I post at 2am... hazukashii >.<;
oh well... shikatta nai (can't be belped)
hotmilk400
Copper - Posts: 55
Posted: April 02, 2007 at 5:08 PM / IP Logged
you dont need really need a fuse, if you bring it off a cig lighter, but if u want, just use something super small, like 5 amps.. these lights take next to nothing to power.. 14 lights take like 1 amp or soemthing.. i forget what it was...
and there is nothing to these, just Battery -> switch -> cathode -> ground. as long as you got the colors right, its fine.. there super easy
Monday, December 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
