06 Ford F-150 Alarm/Remote Start Wiring
je3169
Copper - Posts: 73
Posted: December 03, 2006 at 4:23 AM / IP Logged
Hey guys I am installing a RS in a 06 F150 and need the wiring diagram I search and found nothing and i also looked in the diagrams but only could find one for the 05 F150 is it the same any help would be great.
Thanks John
Twelvoltz
Platinum - Posts: 2,384
Posted: December 03, 2006 at 9:04 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - FORD / F SERIES LIGHT DUTY / 2006 / Remote Start
[PRINT THIS PAGE]
12volts      lt. GREEN/ purple (20A)       +       ignition harness
Starter      RED / lt. blue       +       ignition harness
Second Starter      N/A
Ignition      dk. blue/lt. green       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      BLACK/ lt. green       +       ignition harness
Second Accessory      N/A
Keysense      BLACK/ pink       +       ignition harness
Power Lock      pink / YELLOW       -       DKP or BCM, green plug, pin 9
Notes: The BCM (Body Control Module) is on the driver side rear cabin wall.
Power Unlock      pink/lt. green       -       DKP or BCM, green plug, pin 1
Lock Motor      pink/black       5wi      DKP or BCM, blue plug, pin 2
Unlock Motor      RED / orange       5wi      DKP or BCM, blue plug, pin 5
Parking Lights+      brown       +       switch or BCM, blue plug, pin 6
Parking Lights-      N/A
Hazards      same as turn signal wires
Turn Signal(L)      lt grn/wht (F), lt grn/org (R)      +       turn signal switch
Turn Signal(R)      wht/lt blu (F), org/lt blu (R)      +       turn signal switch
Reverse Light      BLACK/ pink       +       DKP, gray plug, pin 13
Door Trigger      BLACK/ yel (L), BLACK/ pink (R)       -       DKP, gray plug, pins 22, 23
Notes: The wiring above is for vehicles without keyless entry. Vehicles with keyless entry, the door trigger wires are found at the BCM, green plug. The LF door trigger is BLACK / YELLOW in pin 4. The RF door trigger is BLACK/ pink in pin 5. The LR door trigger is BLACK/ lt. blue in pin 12. The RR door trigger is BLACK/ white in pin 13. Use all wires and diode isolate each.
Dome Supervision      BLACK/ lt. blue       +       DKP, gray plug, pin 6
Trunk/Hatch Pin      N/A
Hood Pin      N/A
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm      N/A
Factory Alarm Disarm      N/A
Disarm No Unlock      N/A
Tachometer      NOT RED / lt. green or red       ac       any ignition coil or fuel injector
Wait to start      N/A
Brake Wire      lt. green       +       brake pedal switch
Parking Brake      lt. GREEN/ red       -       parking brake switch
Horn Trigger      dk. blue       -       switch or BCM, blue plug, pin 12
Memory Seat 1      BROWN / lt. green       -       memory seat switch on seat
Memory Seat 2      BLACK/ orange       -       memory seat switch on seat
Memory Seat 3      N/A       -
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
SecuriLock
Part #: 1100F
Alternate Part1 #: 1100X
Alternate Part2 #: 556SW
Alternate Part3 #: 556UW
Alternate Part4 #: DesignTech 20402
Alternate Part5 #: DesignTech 29402
Notes: Standard on all models. When using the 1100X, a software change to 1100FM is needed.
Smart Starter Kill Relays:      Relay Type:
Starter Relay      Location:
Underdash, Passenger side fusebox, #1
Part #: 6401A
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
je3169
Copper - Posts: 73
Posted: December 03, 2006 at 7:33 PM / IP Logged
Wednesday, December 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
