Amp keeps getting protection error
xorphan
Member - Posts: 15
Posted: December 06, 2006 at 7:49 PM / IP Logged
Wired the following
1 head unit
1 amp
1 sub
since i have the chrysler 300 the car battery is in the trunk...
so i wired the negative ground from the amp straight to the negative on the battery, since it's a few inch's away.
i wired the positive from the amp to the positive on the battery, with a fuse. all the wiring comes from an amp install kit, with the appropriate guaged wiring.
then i connected the remote on the amp, to the auto antenna on my hu. 12 plus & 12v+ wires i tied together and connected them to the positive on the amp.
and the ground from the hu, i wired to the amp negative.
can someone tell me why when i turn up the volume past 12 does the amp protect.
aznboi3644
Gold - Posts: 2,600
Posted: December 06, 2006 at 10:04 PM / IP Logged
"12 plus & 12v+ wires i tied together and connected them to the positive on the amp. "
what do you mean here??
xorphan
Member - Posts: 15
Posted: December 06, 2006 at 10:09 PM / IP Logged
I twisted the ends of them together so that there connected and then connected them to the positive terminal 12v+ on the amp, instead of the 12 plus to acc. and in turn the positive on the amp is connected to the positive on the battery...
DYohn
Platinum - Posts: 10,741
Posted: December 06, 2006 at 10:18 PM / IP Logged
What make/model is the amp?  What is the impedance load of the sub?  How did you set your gain?  And what the HECK do you mean when you say:
Did you somehow power your HU through the amplifier positive connection terminal?
aznboi3644
Gold - Posts: 2,600
Posted: December 06, 2006 at 10:45 PM / IP Logged
Still don't get what you're trying to say man...seriously
Basically sounds like you said you connected the remote lead to the amp power...which is constant
jeffchilcott
Platinum - Posts: 2,483
Posted: December 06, 2006 at 11:21 PM / IP Logged
from what I get, he connected the deck to the amp instead of the factory wiring...I dont know why but ok
again, we need the make and model of both the sub and the amp you are trying to run
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
xorphan
Member - Posts: 15
Posted: December 07, 2006 at 4:28 AM / IP Logged
Lanzar 4000 watts mosfet 2 ch - with remote bass boost.
Lanzar 2000 Watts 15" sub
i baught these items as a kit from the manufacturer, so there definately compatible.
just to clarify i did connect the deck straight to the amp.
because i'm not mounting this deck in dash, i will run it under the seat, i will not use the cd EVEr because i don't burn cd's, the source of my audio is my harmon kardon drive and play which add's ipod on dash control and lcd. also i have the chrysler 300c 2006 which were built with a mercedes similar electrical system, meaning the battery for the car is in the trunk.
so to avoid running alot of wire everything is short and sweet... obviously not so sweet though.
i've also double checked all the fuses none are blown, so i'm not understanding why the deck won't pass volume 12 it did initially but don't no what i did...
xorphan
Member - Posts: 15
Posted: December 07, 2006 at 4:37 AM / IP Logged
Amp Specs
    * 2 x 1000 Watts RMS at 4 Ohms
    * 2 x 2000 Watts Max at 4 Ohms
    * 1 x 4000 Watts Max at 4 Ohms Bridged
    * 2 x 1650 Watts at 2 Ohms RMS
    * Electronic Crossover Network
    * Bass Boost Circuit
    * Variable Phase Shift Control
    * 2 Ohms Stereo Stable
    * Anti-Thump Turn-On
    * Soft Turn On/Off
    * High & Low Level Inputs
    * Blue Light Illuminated Crossover Control
    * Power & Protection LED Indicators
    * Advanced Protection Circuitry
    * Bass Boost Remote Control
    * T.H.D: 0.04%
    * S/N Ratio: 90dB
    * Channel Separation: 65dB
    * Frequency Response: 15Hz- 35kHz
    * Dimensions: 10.47"W x 2.46"H x 21"L
Sub Specs
    * Black Non-Pressed Paper Cone
    * Specially Treated Foam Edge Suspension
    * Stamped Steel Basket w/Hex Key Input Terminal
    * Bumped & Vented Motor Structure
    * Custom Designed Rubber Magnet Boot
    * 2.5'' Dual Layer High Temperature Kapton Voice Coil
    * 100 + 100 oz. Heavy Double Stacked Magnet Structure
    * 2000 Watts Peak Power
    * 1200 Watts RMS
    * Dual 4 Ohms Nom. Impedance
    * SPL: 92dB
    * Mounting Depth: 7.2"
    * Overall Diameter: 15.4"
Wiring used
    * 20ft Silver Power Cable w In-Line Fuse Holder
    * 3ft Transparent Black Ground Cable
    * 16ft Blue Remote Cable
    * 1 Pair of 17ft Clear RCA Audio Cables
    * 30ft Clear Dual Conductor Speaker Cable
Head Unit wires
rear rca
rear view camera
video out
sub-out
coaxial out
b- parking brake
b+ 12v rear camera switch
the above wiring is built into the unit.
below is the wiring harness that also connects to the unit.
rear left speaker -
rear left speaker +
rear right speaker -
rear right speaker +
front left speaker -
front left speaker +
front right speaker -
front right speaker +
front rca
video out
auto antenna / with in line fuse
the following wires run through a fuse box also connected to the wiring harness
12 plus
12v+ memory
ground
DYohn
Posted: December 07, 2006 at 8:32 AM / IP Logged
How is the sub wired to the amp?  How is the gain set?
jeffchilcott
Posted: December 07, 2006 at 11:24 AM / IP Logged
sounds like you have it wired bridged to the amp, which is not compatible.
The amp you have will not take a 2 ohm mono load.
Un Bridge your amp before you let the magic smoke out
2007 World Record
