1989 Mercedes 190 Remote Start
666arc
Posted: December 30, 2006 at 10:47 AM / IP Logged
Hi all
Read through various posts and still can't get my remote start to work correctly.
It primes the fuel pump and cranks the engine but just doesn't fire up.
The alarm is a Falcon Predator EVO4 and I've connected as follows :
Alarm Connection 1 should be connected to "On" ie gives 12v when key in any position incl cranking - connected to RED / Green in Ignition harness.
Alarm Connection 2 should be connected to Start - connected to Violet/White in ignition harness
Alarm Connection 3 should be connected to Acc - connected to RED / Black in ignition harness
Alarm Connection 4 should be connected to constant 12V - conencted to Red in ignition harness
Please could anyone help to shred any light on this.
Andy
wlmpwlmp
Copper - Posts: 59
Posted: December 31, 2006 at 9:27 AM / IP Logged
 you say your alarm 1 wire needs constant power and you have connected  to RED / green? use your test light on this wire i believe this is the heater/accesory!!  the constant in your car is red. starter PURPLE / w white. ign 1 RED / w black, ign 2 red w/ yellow, and heater is RED / w green. it looks as tho you are missing that second ign connection.
WesMan
Thursday, June 6, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
