sirius to aftermarket radio 05 ram
hellsyeah4
Posted: December 31, 2006 at 8:56 AM / IP Logged
i want to keep stock sirius unit on a 2005 dodge ram quadcab and put in an aftermarket sirius ready radio. Will the plugs match? also by swithing radios will i be able to see song info on the screen? The stock nav/radio unit doesn't show the info.
KarTuneMan
Platinum - Posts: 7,056
Posted: December 31, 2006 at 9:58 AM / IP Logged
On the OE readio...I believe the serius part is inside the radio, not plugged into the back. Just the antenna is in the back of the readio..?
hercules130
Posted: December 31, 2006 at 12:20 PM / IP Logged
The sirrius is behind the rear seat, at least on my quad cab. I have askes about this and the best i would be able to do is possobly reuse the stock antenae.  To do this i you would need a 2 to 1 adapter for the older 2 wire antenae on our rams. I have been holding off because i am still working out the details on a double din install.
2005 dodge ram 3500 4x4 cummins turbo diesel
hellsyeah4
Posted: January 01, 2007 at 3:29 PM / IP Logged
I have the under the rear seat type
