f250 super duty aux input
rkaczar
Member - Posts: 16
Posted: January 03, 2007 at 7:33 PM / IP Logged
i have a sirius plug and play unit going into a 2006 f250 superduty and all the of the available radio stations for the wireless fm modulator can't be used. i'm curious as to what aux input interface to use with the factory radio or if there is another way to make it work. any help would be appreciated.
f150fan
Copper - Posts: 95
Posted: January 03, 2007 at 10:26 PM / IP Logged
I havent seen any auxillary inputs for the ford radios yet. There may be one out that I dont know about but probably the best thing would be to use a wired in fm mod. On most of the new Sirius units the built in wireless fm mod signal is pretty weak but using a wired in fm mod should fix the problem and on that truck it should be pretty easy to do.
gsam321
Member - Posts: 26
Posted: January 04, 2007 at 12:06 PM / IP Logged
Unfortunatley the F-250 radio was programmed to not accept any input devices. That Aux button is a little misleading. You could get a radio from the F-150 and use and audio input device.
rkaczar
Member - Posts: 16
Posted: January 04, 2007 at 9:45 PM / IP Logged
thanks for the help. i'm going to try the wired fm modulator, but if for some reason that fails then i'll try and scrounge up an f150 radio. thanks again
f150fan
Copper - Posts: 95
Posted: January 04, 2007 at 10:01 PM / IP Logged
Sirius actually has a wired fm mod that they are marketing for most of the newer sirius units. The part # is FMDA25. Audiovox also makes a pretty good unit but I am not sure of the part #.
dudek38
Copper - Posts: 250
Posted: January 05, 2007 at 7:11 PM / IP Logged
im so sick of plug and play units. i use to install them without regret but now i've had enough, especially when i try to use an aux box from pac or a stupid gm antenna adapter from metra that dont stick in far enough on gm radios. then lets pick up some engine noise from an fm mod. gee, fun!!!
"sorry customers", either go somewhere else or put in a sat radio reday head unit.
owner of
Motion Marine & Car Audio
the florida keys
cliffhucker
Posted: January 08, 2007 at 9:23 PM / IP Logged
I have a 2007 F-250 Sup Duty and am installing a AUX input to my factory radio tommorrow.
I will be using it for my Ipod and Sirius.
http://www.logjamelectronics.com/piefrd04aux.html
http://www.tss-radio.com/frd04aux-p-4071.html
Hope this helps.
Cheers
jimmy303
Member - Posts: 19
Posted: January 15, 2007 at 10:21 AM / IP Logged
cliffhucker
Posted: January 15, 2007 at 1:21 PM / IP Logged
jimmy303,
Why did you post a link for the same thing I did at $30 more?
TSS radio has the absolute best price on the FRD-04
Cheers
jimmy303
Member - Posts: 19
Posted: January 16, 2007 at 7:33 AM / IP Logged
Haven't had my coffee, yet. Sorry.
time is bending.....
