Fork lift Remote kill system
bareaudio
Posted: January 04, 2007 at 3:30 PM / IP Logged
I'm trying to figure out the simplest way to set this up, a friend of mine has about 30 forklifts, on each one he wants just the opposite of a remote start system, a remote kill system, basically i'm looking for a one channel output system, That I don't have to modify very much, Can you give me any suggestion on product.
Nothings impossible! Just takes good engineering.
Big Dog
Gold - Posts: 1,265
Posted: January 04, 2007 at 3:36 PM / IP Logged
How about SSKR smart relays from DEI? Pop out OEM ignition or starter relay and replace with SSKR then program remote. One remote per lift or possible to have a master remote which disarms all.
Prepare your future. It wasn't the lack of stones that killed the stone age.
floaterr
Silver - Posts: 383
Posted: January 06, 2007 at 8:48 PM / IP Logged
buy the cheapest keyless entry system on the market that has a starter kill outputs. Wire the relay backwards. In other words, when the alarm is armed have it flip the relay and make the connection for the ignition system. You'll probably want to make sure and not connect the IGN wire to the alarm. Most wont arm with the IGN on..
Wednesday, July 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
