97 Expedition courtesy lights stay on
Rusty Williams
Posted: January 30, 2003 at 8:46 PM / IP Logged
The inside dome light stays on after door is shut. lights will eventually turn off based on speed or time, not sure which. however, the Door Ajar dummy light on dash stays lit. After leaving vehicle the dome light and running board lights will stay on for undetermined amount of time. Battery was dead this morning. I see the Door trigger wire is blue/White, and something about a RAP module????? Any help here?
Rusty
ViperATC5
Copper - Posts: 202
Posted: January 30, 2003 at 8:53 PM / IP Logged
ive encountered the same problem in the same vehicle, however it turned out to be entirely mechanical and nothing electrical - the pin switch on this truck for the doors is actually part of the lock mechanism inside each door- on the truck that I had the problem with, the switch in the drivers door was faulty and needed to be replaced by ford.  To temporarily solve the problem for the customer we went into the drivers door and disconnected the wire going to the lock mechanism so that it would not read the door as being open when it was actually shut
Rusty Williams
Posted: January 30, 2003 at 8:57 PM / IP Logged
Would that be the Door Trigger wire?
Rusty
ViperATC5
Copper - Posts: 202
Posted: January 30, 2003 at 10:05 PM / IP Logged
not the one inside the vehicle - the one inside the car is common for all the doors and the rear hatch, u have to go into the door and find the wire going to the lock mechanism
paul1971
Posted: February 14, 2003 at 12:18 PM / IP Logged
i had the same problem open the door and where the latch is take a screwdriver and some wd40 and spray in the door latch and work latch back and forth there is a switch in there that gets dirty and sticks try it on all the doors even the rear hatch
friend
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
