Parrot 3100 and Onstar
pitoaudiovisual
Copper - Posts: 388
Posted: January 22, 2007 at 11:29 AM / IP Logged
I installed a Parrot kit to a Chevy Envoy and now the Onstar doesn't work it is possible that i may need to connect other wires cause i only connected the two front speakers and the mute wire. do you think the mute wire maybe the cause of why the Onstar no longer works. It doesnt work with the car on or off and also with the kit on or off.. Thanks in advance.
Confidence is the key to any project!!
elicoleman
Copper - Posts: 72
Posted: January 24, 2007 at 1:28 PM / IP Logged
What year is the Envoy?
2003 GMC Yukon, Kenwood 815DVD w/ Nav. Memphis speakers. Kenwood 1200W Amp, Alpine 400W amp. Rear view camera, headrest monitors. Parrot CK3100
pitoaudiovisual
Copper - Posts: 388
Posted: January 24, 2007 at 8:48 PM / IP Logged
06
elicoleman
Copper - Posts: 72
Posted: January 25, 2007 at 10:59 AM / IP Logged
Not sure what happen. I hook these up all the time to GM vehicles with On-Star and have yet to have a problem. Where did you get your power's from. Your 12v Acc needs to come off the ingnition switch in th column (brown wire I belive). I would pull the kit out and see if the On-star is ok then use the cell cite GMSS-2 harness with Parrot-1 adapter. It is hard to mess up the install with this harness. Good luck
blackbear
Posted: February 01, 2007 at 3:57 PM / IP Logged
check out www.coastaletech.com/GMLOCKPICK.htm
- Bill
pitoaudiovisual
Copper - Posts: 388
Posted: April 23, 2007 at 11:45 AM / IP Logged
im sorry i didnt get back to you guys about why the onstar wasn't working . the company i ordered the harrness from told me that they make 2 different harrnesses for this vehicle and sent me the wrong one. they sent me the right harness and its working fine.. thanks again.
You can vote in polls in this forum
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
