791xv starter wire connection
xxkevo
Posted: January 22, 2007 at 10:16 PM / IP Logged
i have a quick question on hooking up the 791xv remote start,
for the heavy guage wire the purple and green wire both connects to the starter wire,
the purple is on the starter side
the green is on the key side
so does this mean i just cut the starter wire in half?  and then tap the  purple to the starter side and the green to the key side?
OR
do am i NOT suppose to cut it and just T tap it to side its suppose to be on?
thanks...
captainzab
Silver - Posts: 606
Posted: January 22, 2007 at 11:05 PM / IP Logged
this topic is a massive repeat, but anyways
your suppose to cut the starter wire in half, and purp to starter and green to key side.
Note: You Always Dont Get What You Pay For.
f150fan
Copper - Posts: 95
Posted: January 23, 2007 at 2:52 PM / IP Logged
I would strongly recommend soldering this connection since if the connection fails the vehicle will not start.
dre187
Copper - Posts: 129
Posted: January 23, 2007 at 9:30 PM / IP Logged
If you do not want to connect starter-kill, you  can just tap the purple wire onto the vehicle's starter wire and leave the green wire unused. If you do want starter-kill, the above stated is right...
xxkevo
Posted: January 23, 2007 at 10:56 PM / IP Logged
would there be any benefit for me to hook up the starter kill, if my car is a 2001 honda accord with the chiped key? thanks
duct tape
Copper - Posts: 125
Posted: January 23, 2007 at 11:32 PM / IP Logged
the benefit is the antigrind feature, this way when the car is remote started, you cant grind the starter by turning the key too far.
spookiestylez
Silver - Posts: 531
Posted: January 24, 2007 at 12:43 AM / IP Logged
great built in feature....if your car has a factory immobilizer built in and you DONT want the starter kill or anti grind feature...just connect the purple wire and cap/tape off the green wire
rtfm
