95 jetta ignition lock being a prob w RSt
hotlead44
Posted: January 25, 2007 at 11:13 PM / IP Logged
I have this jetta with remote start installed. The issue is that when remote is started and then the key is inserted into the ignition the doors lock and then the factory alarm becomes armed. then opening a door sets off the horn with the key still in.
I need to get rid of the factory alarm or turn of the ignition locking. and I know that its armed with the locks so any ideas, thanks a lot
profuse007
Gold - Posts: 2,015
Posted: January 25, 2007 at 11:33 PM / IP Logged
new installation?
whats the RS unit make/model?
Houston,TX
KarTuneMan
Platinum - Posts: 7,056
Posted: January 25, 2007 at 11:38 PM / IP Logged
On the factory alarm module you need to "break" the ignition INPUT wire. It's pin 4 and black. It's under the drivers side dash kind behind the light switch. there are a 10mm bolt  to get the box to drop down. Cut the black pin 4 ign. input wire, put one end on pin 87a, and the other end on 30. Pin 85 gets 12volts, pin 86 gets ground while running, or status output (DEI). Just remeber ground while running to trigger the relay!
hotlead44
Posted: January 26, 2007 at 12:55 PM / IP Logged
ima give it a shot, thanks for taking the time.
