autostart led issue
Copper - Posts: 82
Posted: February 14, 2007 at 8:57 PM / IP Logged
I put an AUTOSTART bran RS in my dads 94 Chev Truck, everything works perfectly the only thing that doesnt is the blue LED on the antenna, in valet mode, it will stay solid, so i know that it works, but on a regular basis it does not flash like its suppose to, the only time its on actually is in valet mode, any insight on why it doesnt blink?
Matthew Robertson
Senior Installer
Best Buy Deerfoot Meadows
Calgary, AB, Canada
dre187
Copper - Posts: 129
Posted: February 14, 2007 at 9:07 PM / IP Logged
you can turn the the l.e.d. off. check the install manual for the progrqming sequence to change it. pretty easy to do
dea,can
Copper - Posts: 284
Posted: February 15, 2007 at 3:12 AM / IP Logged
try pushin the lock button should blink then
dragon
thepencil
Gold - Posts: 1,526
Posted: February 15, 2007 at 9:03 AM / IP Logged
What model is this?
Be careful whose advice you buy, but be patient with those who supply it.autostart led issue - Last Post -- posted image.
Monday, July 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
