viper remote for clifford matrix
sporttrac
Member - Posts: 10
Posted: March 04, 2007 at 8:44 PM / IP Logged
I have the Clifford Matrix 10.5 (i think), with the LCD remote. Well I broke my LCD and I am able to get a Viper LCD remote a lot cheaper than the Clifford one, so can i use it? are they compatible? Thanks in advanced.
kgerry
Platinum - Posts: 3,455
Posted: March 05, 2007 at 9:27 AM / IP Logged
the remote for a Viper 5000 would be compatible....     just don't expect to use a Responder remote.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
sporttrac
Member - Posts: 10
Posted: March 05, 2007 at 3:45 PM / IP Logged
So the display wont work?
kgerry
Posted: March 06, 2007 at 8:31 AM / IP Logged
the display would work with the proper compatible remote... but the Responder units are FSK and the 10.5X & 5000 are ASK... they are only "Responder looking" not a true Responder remote......
you need a 489 V/X/P  remote.......
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
tattootre
Posted: March 21, 2007 at 7:47 PM / IP Logged
i also have a question along the same lines, i have a Matrix 2.5 installed in which i broke the first remote, and have purchased a viper remote and was told it would work, (remote RPN 479v/p/x) after linking the remote i find that only the channel 1 button works, and it locks and unlocks, instead of just locking. and the other buttons don't do anything. is there a way around this?
nava94
Silver - Posts: 296
Posted: March 21, 2007 at 9:38 PM / IP Logged
reprogram the remote again and read the instruction it came with. you have programed it to use the lock button to arm and diarm. read the instructions and you will have the lock button arming the alarm and the unlock button disarming the alarm, along with the spare channels on the remote will work okay.
tattootre
Posted: March 24, 2007 at 8:55 AM / IP Logged
thanks, that worked. i should have done it myself in the first place.
kgerry
Posted: March 24, 2007 at 1:37 PM / IP Logged
it's usually best when learning a remote to "auto-learn remote"... much quicker and easier.....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Friday, July 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
