Posted: May 08, 2007 at 10:53 PM / IP Logged
Posted: May 09, 2007 at 12:01 AM / IP Logged
Posted: May 09, 2007 at 5:58 AM / IP Logged
Posted: May 09, 2007 at 9:31 AM / IP Logged
Posted: May 09, 2007 at 9:45 AM / IP Logged
Posted: May 09, 2007 at 5:22 PM / IP Logged
Posted: May 10, 2007 at 3:43 AM / IP Logged
Posted: May 10, 2007 at 3:45 AM / IP Logged
Posted: May 10, 2007 at 9:14 AM / IP Logged
Posted: May 10, 2007 at 10:07 AM / IP Logged
Wednesday, March 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
A and C appear to be the two sides of the coil. You can check for a circuit using a multimeter (should be near infinite resistance between them). If they are there should be 12V live from the switch connected to one and earth to the other. Doesn't matter which.
E appears to be the common terminal and fused 12V from the battery should be connected here.
B and D then are the normally closed and normally open terminals. I can't tell from the diagram which is which. There should be a circuit between normally closed and the common terminal when no power is applied to the relay. When the coil is energised there will be a circuit between the common terminal and the normally open terminal.
