pioneer avic d3 in 07 silverado
billyeins
Posted: May 14, 2007 at 12:58 PM / IP Logged
My installer says if he installs the Pioneer AVIC D3 in place of the GPS system that came with my new 07 Chevrolet Silverado Crewcab, the rear DVD will not work.
Is there a kit or way to install the Pioneer AVIC D3 in my vehicle so the rear DVD will work?
roland stec
Posted: May 15, 2007 at 5:09 PM / IP Logged
 gm does not use the RCA style connections, good luck on that one
RS
Carsounds etc.
Surrey B.C.
Mike M2
Platinum - Posts: 2,652
Posted: May 17, 2007 at 6:58 PM / IP Logged
It can work if you know how to do it. You need to run signal from the D3 up, then supply the factory DVD with power. It's a little complicated but we do it a lot as we are exbiditors. I don't care for using the D3 for this as you won't be able to use the nav unless you set a course first, and you won't be able to listen to a disc while the DVD is playing. A better choice is the Z1....
Mike M2
Tech Manager
CS Dealer Services
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
