2007 highlander, gps nav system
juhlm
Member - Posts: 6
Posted: October 03, 2007 at 7:55 PM / IP Logged
Kar Tune Man,
I have a question.  I am installing a GPS Nav system in an 07 HIghlander.  The Wire Magic database says a yellow wire on the 2nd plug down on ECM for the VSS.  There are 3 on this connector, None of which show alternating current.  Any suggestions?  Can I use a tach wire?
Mike
Mike
North Carolina
sparkie
Platinum - Posts: 2,061
Posted: October 03, 2007 at 8:09 PM / IP Logged
You can't use a tach wire as this is engine speed and not vehicle speed. The VSS wire should be in the top corner of the second plug from the top behind the glove box.
sparky
Mike M2
Platinum - Posts: 2,652
Posted: October 04, 2007 at 6:42 AM / IP Logged
It will be pin 17....
Mike M2
Tech Manager
CS Dealer Services
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
