amp output voltage calculation
Alpine Guy
Platinum - Posts: 2,478
Posted: October 19, 2007 at 9:22 AM / IP Logged
What calculation do you use to determine your voltage output on your amplifier when setting the gain? For example, I just repaired my Crossfire VR2000D and want to test it's output voltage, I can either run it with no load 0 ohm of course, or 4 ohm with a load which is supposed to have an rms rating of 1000 wrms.
How is it done for testing, this has never been made clear to me.
haemphyst
Platinum - Posts: 5,059
Posted: October 19, 2007 at 10:18 AM / IP Logged
Square root of power times resistance.
1000*4=4000
sqrt of 4000=63.245553203367586639977870888654v
(or roughly 63.25V RMS) LOL
And just a small correction, 0 ohms is a dead short. You meant open, which is ~ infinite. You said it right, just used the wrong polynomial. amp output voltage calculation - Last Post -- posted image.
DYohn
Platinum - Posts: 10,741
Posted: October 19, 2007 at 10:22 AM / IP Logged
If you are trying to load test the amp, you will need to place a power resister across the output terminals.  Typically an 8 or 16 ohm load is used.  If you are trying to set the input gain, calculate what the voltage should be for the speaker load you intend to use (use Ohms Law) then apply the max input level you intend to use and adjust the input gain with no speaker connected until your AC volt meter indicates your calculated voltage.
Alpine Guy
Posted: October 19, 2007 at 1:28 PM / IP Logged
Perfect, thanks.
aznboi3644
Gold - Posts: 2,600
Posted: October 20, 2007 at 1:04 AM / IP Logged
when doing this i've been told to have the speakers wired up so the amp has a load.
what is the difference of doing this without a load and with a load??
stevdart
Platinum - Posts: 5,816
Posted: October 20, 2007 at 11:34 AM / IP Logged
No load = no output.
DYohn
Posted: October 20, 2007 at 11:49 AM / IP Logged
Input gain should be set with speakers disconnected.
aznboi3644
Gold - Posts: 2,600
Posted: October 20, 2007 at 11:58 AM / IP Logged
you mean turning up the gain on the amp with no speakers connected??
DYohn
Posted: October 20, 2007 at 12:20 PM / IP Logged
Yes.  Set your gain without any speakers connected to the amplifier.
  1. Disconnect speakers.
  2. Turn your gain/input sensitivity all the way down. Turn off any bass boost and bypass crossovers.
  3. Turn on your head unit. Set the volume control to approx 3/4 of full, or to the point just below where clipping begins. Set all equalization and bass/treble controls to zero. Turn off loudness or BBE processing, etc.
  4. Connect your AC voltmeter to the amplifier's output channel.
  5. Insert test tone CD. Select a tone within your amplifier's intended frequency range.
  6. Adjust the gain until you reach the calculated target voltage for output into your speaker's load.
  7. Reconnect your speakers and verify proper operation. Set crossovers and adjust levels down if necessary to achieve tonal balance.
haemphyst
Posted: October 20, 2007 at 10:08 PM / IP Logged
Ummmm.... No. No load=no POWER. Output voltage will still exist, AND follow the input voltage, but because there is no current (because there is no load) there is no power.
