2005 altima 2.5s gauge removal nav?
fly4awhtgye1
Posted: November 02, 2007 at 10:00 AM / IP Logged
I am working on removing the gauge cluster to hook up an Eclipse AVN2454 navigation system and can't find the bottom 2 screws to remove the dash cluster. I already have the top 2 screws removed. Can someone please describe where to find them? I heard to find the screws behind the rubber under the steering wheel shroud, but still couldn't find them.
My understanding is that the VSS wire is yellow/blue behind the cluster. Is the reverse wire behind the cluster also or only GREEN / WHITE in the driver's kick panel?
Any help will be great. Thanks.
Platinum - Posts: 13,725
Posted: November 03, 2007 at 7:01 AM / IP Logged
I am pretty sure that the VSS wire is in the radio harness.  It is there for the mid-line radio, it should be there for the nav unit.
fly4awhtgye1
Posted: November 06, 2007 at 6:33 PM / IP Logged
Thanks for the reply. My basic 2.5s harness didn't have the VSS wire in the harness.
I thought I tapped the blue/white wire behind the gauge cluster correctly, but get a "CHECK SPEED PULSE" message whenever navigation is used. Any ideas?
Mike M2
Platinum - Posts: 2,652
Posted: November 09, 2007 at 6:44 AM / IP Logged
The bottom two screws are buried under the guages in that crack. You need a long pillips driver and you can get them out...
Mike M2
Tech Manager
CS Dealer Services
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
