2007 jeep cherokee laredo vss
live42day
Member - Posts: 26
Posted: November 08, 2007 at 6:22 PM / IP Logged
Does anyone have the vss (vehicle speed sense) & reverse light wire info for this vehicle? I have searched with no luck. 2007 Jeep Cherokee Laredo.
Thank you in advance.
extreme1
Silver - Posts: 1,070
Posted: November 08, 2007 at 9:31 PM / IP Logged
PAC C2R-CHY will give you all the nav outputs you need.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
live42day
Member - Posts: 26
Posted: November 12, 2007 at 9:02 PM / IP Logged
Thank you for the reply, but for $80.00 I'll pass. I would rather just tap the VSS and the reverse light wight wires.
Anyone know this info?
Thank you in advance!
Mike M2
Platinum - Posts: 2,652
Posted: November 13, 2007 at 6:14 AM / IP Logged
I think you may have to reconsider spending the money. Some Chrysler products it is impossible to find a VSS unless you decode it from data, and the Laredo may be the same way.
Mike M2
Tech Manager
CS Dealer Services
live42day
Member - Posts: 26
Posted: November 13, 2007 at 2:46 PM / IP Logged
I dint know that. Thank you. Which really sucks cuz I already bought the metra adapter to swap the radio for $70.00.
Is that PAC C2R-CHY the only option to get that wire through data since I already bought the metra one?
techman93
Silver - Posts: 591
Posted: November 13, 2007 at 9:23 PM / IP Logged
Speed Sense DK GREEN/ BROWN    (AC) AT PCM, IN BLACK/ GREEN PLUG, PIN 32
Reverse Lights     WHITE/ LT GREEN     (+) AT IPM, CONNECTOR 2, PIN 2
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
xdrtypopx
Posted: December 18, 2007 at 12:18 PM / IP Logged
All my research says that the wire should be in plug 4 (a green plug at the PCM).  However when i go to locate this i see the 4 spots for Plugs (Black, Orange, White, Green) but only the first 3 actually have a harness plugged into them.  The green one in this car is non existent.  Any thoughts... Thanks!
silverrage
Posted: January 06, 2008 at 1:56 PM / IP Logged
it is still to high of a signal I tried to tap it in the new patriot and the navi showed me goin' about 90mph when I was doin' 20mph the new canbus jeeps have a high and low vss neither can be used for a nav unit u need to get the Pac or peripheral module to get the vss
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
