'07 avalanche and can sl2 bypass
brcidd
Copper - Posts: 274
Posted: November 15, 2007 at 4:36 PM / IP Logged
From my research, I am having trouble learning if this module will bypass the transponder- the charts have a big red "x" in this category- yet say it does or can- yet I don't see an antenna ring for the ignition barrel either on the instructions... will this module allow the truck to start remotely?  One chart shows it as an OEM ignition key - so I am confused-- Has any used this to "do it all" ?  Thanks
Brcidd - Engineer That Does Remote Starter Installs on the side.
Bnluis
Silver - Posts: 578
Posted: November 15, 2007 at 4:41 PM / IP Logged
if u get the module with the latest version it will do transponder. The module has just recentlly been improve and it will do everything on that car. look at the manual. ( P.s if u are not registered it will take a while to load)
http://bypasskits.fortinautoradio.com/en/vehicles/2007/chevrolet/avalanche/
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
