2008 Nissan Pathfinder Alarm/Remote Start Wiring
installperson
Posted: November 29, 2007 at 8:18 PM / IP Logged
What are the wire colors for this truck is it the same as the 05,06 or not if not do you know what wires
techman93
Silver - Posts: 591
Posted: November 30, 2007 at 7:48 AM / IP Logged
WIRE          COLOR          POLARITY          LOCATION
Battery          GREEN          (+)     IGNITION SWITCH HARNESS
Ignition 1     WHITE/ GREEN     (+)     IGNITION SWITCH HARNESS
Starter 1     GRAY          (+)     IGNITION SWITCH HARNESS
All Door Trigger BROWN             (-)     AT BCM MODULE BEHIND DRIVERS SIDE OF DASH ABOVE PEDALS BEHIND DIAGNOSTIC CONNECTOR     PIN #63
Domelight Super     BROWN          (-)     AT BCM MODULE BEHIND DRIVERS SIDE OF DASH ABOVE PEDALS BEHIND DIAGNOSTIC CONNECTOR     PIN #63
LF Latch     GRAY          (-)     AT BCM MODULE BEHIND DRIVERS SIDE OF DASH ABOVE PEDALS BEHIND DIAGNOSTIC CONNECTOR     PIN #47
RF Latch     LIGHT GREEN     (-)     AT BCM MODULE BEHIND DRIVERS SIDE OF DASH ABOVE PEDALS BEHIND DIAGNOSTIC CONNECTOR   PIN #12
LR Latch     PINK          (-)     AT BCM MODULE BEHIND DRIVERS SIDE OF DASH ABOVE PEDALS BEHIND DIAGNOSTIC CONNECTOR     PIN #48
RR Latch     BLUE             (-)     AT BCM MODULE BEHIND DRIVERS SIDE OF DASH ABOVE PEDALS BEHIND DIAGNOSTIC CONNECTOR     PIN #13
Trunk Trigger     YELLOW          (-)     AT BCM MODULE BEHIND DRIVERS SIDE OF DASH ABOVE PEDALS BEHIND DIAGNOSTIC CONNECTOR     PIN #43
Parking Lights     RED & GRAY & GRAY     (+)     AT INTELLIGENT POWER MODULE ON PASSENGER SIDE OF FIREWALL UNDER HOOD     PIN #28 & #49 & #57 - MUST ISOLATE AND POWER ALL THREE WIRES TO OPERATE PARKING LIGHTS.
Parking Brake          GREEN          (-)     AT PARKING BRAKE SWITCH OR IN HARNESS BEHIND GAUGES
Trnk Release          LOCKS AND UNLOCKS WITH ALL OTHER DOORS.
Fuel Dr Release          LOCKS AND UNLOCKS WITH ALL OTHER DOORS.          Battery          GREEN          (+)     IGNITION SWITCH HARNESS
Ignition 2     RED          (+)     IGNITION SWITCH HARNESS
Ignition 3     WHITE/ RED     (+)     IGNITION SWITCH HARNESS
Accessory 1     GREEN/ YELLOW     (+)     IGNITION SWITCH HARNESS
Anti-Theft Type          NISSAN NVIS® VEHICLE IMMOBILIZER
Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense     BLACK          (+)     AT BCM MODULE BEHIND DRIVERS SIDE OF DASH ABOVE PEDALS BEHIND DIAGNOSTIC CONNECTOR     PIN #37
Tachometer
     THE VEHICLE TACHOMETER SIGNAL IS SENT THROUGH A DATABUS LINE - YOU MUST USE A CRANKSHAFT OR CAMSHAFT POSITION SENSOR OR A FUEL INJECTOR SIGNAL WIRE.
Crankshaft Sensor     GREEN     (+)     AT ECM MODULE ON PASSENGER SIDE OF FIREWALL UNDER HOOD     PIN #13
Camshaft Sensor          BLUE     (-)     AT ECM MODULE ON PASSENGER SIDE OF FIREWALL UNDER HOOD     PIN #33
Speed Sense          THE VEHICLE SPEED SIGNAL IS SENT THROUGH A DATABUS LINE - YOU MUST USE A WHEEL SPEED SENSOR WIRE.
Brake Lights     YELLOW          (+)     AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights     LIGHT BLUE     (+)     IN HARNESS IN DRIVERS DOOR SILL
Horn          BROWN          (-)     IGNITION SWITCH HARNESS
Anti Theft RX     GRAY          (DATA)     IGNITION SWITCH HARNESS
Anti Theft TX     BROWN          (DATA)     IGNITION SWITCH HARNESS
Power Unlock     LIGHT GREEN     (-)     AT BCM MODULE BEHIND DRIVERS SIDE OF DASH ABOVE PEDALS BEHIND DIAGNOSTIC CONNECTOR     PIN #46 - THIS WIRE CAN BE FOUND AS WHITE (-) IN DRIVERS DOOR HARNESS ALSO.
PowerLock     VIOLET          (-)     AT BCM MODULE BEHIND DRIVERS SIDE OF DASH ABOVE PEDALS BEHIND DIAGNOSTIC CONNECTOR     PIN #45 - THIS WIRE CAN BE FOUND AS LIGHT GREEN (-) IN DRIVERS DOOR HARNESS ALSO.
Driver Mtr Unlock     GREEN     (+)     AT MOTOR IN DOOR
Driver Mtr Lock          VIOLET     (+)     AT MOTOR IN DOOR
Pas Mtr Unlock          GREEN/ YELLOW     (+)     AT MOTOR IN DOOR
Pas Mtr Lock          VIOLET          (+)     AT MOTOR IN DOOR
LF Window Up          ORANGE          (AC)     AT MOTOR IN DOOR
LF Window Dn          GRAY          (AC)     AT MOTOR IN DOOR
RF Window Up          GREEN          (AC)     AT MOTOR IN DOOR
RF Window Dn          BLUE          (AC)     AT MOTOR IN DOOR
LR Window Up          YELLOW          (AC)     AT MOTOR IN DOOR
LR Window Dn          BLUE          (AC)     AT MOTOR IN DOOR
RR Window Up          YELLOW          (AC)     AT MOTOR IN DOOR
RR Window Dn          BLUE          (AC)     AT MOTOR IN DOOR
Sunroof Open     RED     (-)     AT VEHICLE SUNROOF SWITC HARNESS
          THREE-SECOND PULSE TO FULLY OPEN WINDOW.
Sunroof Close     LIGHT BLUE(-)     AT VEHICLE SUNROOF SWITC HARNESS
               THREE SECOND PULSE TO FULLY CLOSE WINDOW.
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
