shortcut with 451m
sicbomb
Member - Posts: 10
Posted: December 04, 2007 at 6:18 AM / IP Logged
I'm almost done with installing a Clifford Matrix 50.5X on a 2008 Mitsubishi Lancer Evolution.  The vehicle is equip with a Smart key system controlled by ETACS CAN Bus system.  I can't seem to find any wires for door lock relays or switches so I plan on doing a short cut and connect directly to the driver's side door lock actuator.  The door lock actuators are a standard 2 wire type and if the driver's side locks or unlocks all the other doors will follow.
Now my question is can I just hook up the Dei 451M to connect to the acuator directly?  Are there any additional items that I'll need for this operation?
SiC
Ex-Installer from KMA Racing Hawaii
Currently working in Japan
Twelvoltz
Platinum - Posts: 2,384
Posted: December 04, 2007 at 6:21 AM / IP Logged
You can use the 451M for that application. Just hook it up using the 5-wire diagram.
sicbomb
Member - Posts: 10
Posted: December 04, 2007 at 6:53 PM / IP Logged
Thanx, I'll give it a try
