2003 f150 lariat door lock actuator
proxac
Posted: December 07, 2007 at 8:26 PM / IP Logged
I have a 2003 F150 Lariat that obviously has power door locks. What I am adding is an after market actuator in another part of the truck. The after market actuator has just 2 wires (not unusual) and from what I can tell the stock actuator (passenger side) has 4. Is this something I can easily tap into? If so what wires do I splice into? This after market one just uses a reverse of + and - to go in or out. I thought thats how the stock one in the door worked too?
Thanks in advance!
mikvot
Gold - Posts: 1,043
Posted: December 12, 2007 at 6:57 PM / IP Logged
Yep....if it's a two wire actuator you can just tie into the motor wires of the factory actuator. I do this all the time when a customer has a factory actuator go bad and doesn't want to pay the dealer to put an oem part in. Lock pink/black (+) and unlock RED / orange (+) are the wires you need. You can find the wires in the door, or under the left side of the dash, against the firewall at the factory keyless entry.
proxac
Posted: December 14, 2007 at 7:57 AM / IP Logged
Thanks. I will get the door panel off today and see if pink/black and RED / orange are there and try em out!
