1996 pontiac sunfire theft light issue
ikethegoalie
Copper - Posts: 79
Posted: December 13, 2007 at 5:48 PM / IP Logged
would just unplugging the bypass work?
howmuchlonger
Member - Posts: 12
Posted: December 13, 2007 at 6:03 PM / IP Logged
I cant see what your install looks like.
If you tripped pk1 you probably have something wrong any how.
I dunno is it more important to you to get the car to start or to mabey have to rewire your bypass?
I have always bypassed these the "old fassion way"  (relay/resistor)
Test it w/your meter!!!
ikethegoalie
Copper - Posts: 79
Posted: December 13, 2007 at 8:24 PM / IP Logged
Ok, the Bypass I am using has just one wire that ties into the yellow wire on the PK system.
I did what you posted earlier, disconnected the remote start brain, disconnected the bypass, (So now there is nothing aftermarket hooked to the car) I then disconnected the battery terminals and touched the two together. (I assumed this is what you meant by ground it out.) Held it for 10-15 seconds.
The theft light is still coming on (solid, not flashing) when the key is turned to Ignition On.
It could not have been one of my connections as I didnt attempt to remote start the car, could it?
ikethegoalie
Copper - Posts: 79
Posted: December 14, 2007 at 8:34 AM / IP Logged
It is more important for me to get the car running at this point in time.
ikethegoalie
Copper - Posts: 79
Posted: December 14, 2007 at 7:47 PM / IP Logged
does anyone know the location of the passlock brain inside the car, or does that ribbon harness from the key cylinder to the BCM/>
moonliter
Copper - Posts: 322
Posted: December 14, 2007 at 8:45 PM / IP Logged
Check the pcm fuse at passenger side fuse box, make sure it wasn't blown.
ikethegoalie
Copper - Posts: 79
Posted: December 14, 2007 at 10:14 PM / IP Logged
good call, i completely forgot about that, would having that fuse blown cause anything else to not work, I.E. starter or anything, because the car cranks, fuel pump turns on, and I believe I have spark.
