need 2010 ford focus remote start wiring
turbobuick1
Member - Posts: 18
Posted: January 16, 2010 at 12:47 PM / IP Logged
Hi guys, I have a 2010 Ford Focus SE and I need a wiring diagram in order to install a remote start. Appreciate any help I can get, thanks a lot!
chev104275
Gold - Posts: 1,436
Posted: January 16, 2010 at 3:31 PM / IP Logged
2010 FORD FOCUS 4DR SEDAN
     Security
     WIRE          COLOR          POLARITY          LOCATION
     Battery          BLUE/RED (20 AMP)          (+)          IGNITION SWITCH
               CAN ALSO GRAB POWER AT LARGE GAUGE WHITE/ RED WIRE AT THE SJB
     Ignition 1          BROWN / YELLOW          (+)          IGNITION SWITCH
     Starter 1          BLUE/WHITE          (+)          IGNITION SWITCH
     All Door Trigger          GRAY/VIOLET          (+)          DRIVERS KICK PANEL
               ALSO FOUND AT SJB, PIN 9 OF 14-PIN GRAY PLUG
     Domelight Super          USE ALL DOOR TRIGGER
     LF Latch          GREEN/ VIOLET *SEE NOTES
               THIS WIRE WILL REST AT GROUND, THEN GOES TO AN OPEN CIRCUIT UPON ENTRY
     RF Latch          WHITE *SEE NOTES
     LR Latch          GREEN *SEE NOTES
     RR Latch          YELLOW *SEE NOTES
     Trunk Trigger          GRAY/ORANGE *SEE NOTES
     Hood Trigger          BLUE/ORANGE *SEE NOTES
     Alarm Disarm          OEM REMOTE ONLY, SEE TECH TIP
     Parking Lights          VIOLET/WHITE          (+)          DRIVERS KICK PANEL
     Remote Start
     Accessory 1          VIOLET/GREEN          (+)          IGNITION SWITCH
     Anti-Theft Type          PATS IMMOBILIZER SYSTEM
     Key Sense          BLUE/GRAY          (+)          IGNITION SWITCH
     Tachometer          UNCOMMON COLOR AT FUEL INJECTORS
     Speed Sense          BROWN / GREEN          (AC)          AT PCM, PIN 4 OF BOTTOM PLUG
               MAY ALSO BE PIN 2
     Reverse Lights          GREEN/ BROWN          (+)          DRIVERS SILL PLATE HARNESS
     Rear Defrost          WHITE/ ORANGE
               THIS IS A LATCHING CIRCUIT
     Heated Driver Seat          YELLOW/BLUE          (-)          AT HEATER CONTROL MODULE IN DASH, PIN 1 OF BLACK 26-PIN PLUG
     Heated Passngr Seat          GRAY/BLUE          (-)          AT HEATER CONTROL MODULE IN DASH, PIN 5 OF BLACK 26-PIN PLUG
     Modules
     WIRE          LOCATION
     Module 1          SJB (SMART JUNCTION BLOCK) - MOUNTED UNDER DASHBOARD ON DRIVERS SIDE
     Doorlocks/Windows
     Power Unlock          YELLOW/VIOLET          (-)          DRIVERS KICK PANEL
               ALSO FOUND AT SJB, PIN 4 OF 26-PIN GRAY PLUG
     PowerLock          BLUE/GREEN          (-)          DRIVERS KICK PANEL
               ALSO FOUND AT SJB, PIN 17 OF 26-PIN GRAY PLUG
     Driver Mtr Unlock          BLUE/GREEN          (REV)          DRIVERS KICK PANEL
               ALSO FOUND AT SJB, PIN 28 OF 32-PIN BLACK PLUG
     Driver Mtr Lock          GRAY/BROWN          (REV)          DRIVERS KICK PANEL
               ALSO FOUND AT SJB, PIN 6 OF 32-PIN BLACK PLUG
     Pas Mtr Unlock          VIOLET/GRAY          (REV)          PASSENGERS KICK PANEL
               ALSO FOUND AT SJB, PIN 27 OF 32-PIN BLACK PLUG
     Convenience
     Headlights-Lo          YELLOW/BLUE          (-)          HEADLIGHT SWITCH
               ALSO FOUND AT SJB, PIN 30 OF 52-PIN BLACK PLUG
     All Hazrd Lights          BROWN / YELLOW          (-)          AT SWITCH
               ALSO FOUND AT SJB, PIN 48 OF 52-PIN BLACK PLUG
     LF Hazrd Bulb          BLUE/GREEN          (+)          SJB, PIN 21 OF 26-PIN BLACK PLUG
     RF Hazrd Bulb          YELLOW/VIOLET          (+)          SJB, PIN 23 OF 26-PIN BLACK PLUG
     LR Hazrd Bulb          GRAY/BROWN          (+)          SJB, PIN 25 OF 32-PIN BLACK PLUG
     RR Hazrd Bulb          VIOLET/ORANGE          (+)          SJB, PIN 26 OF 32-PIN BLACK PLUG
     Trnk Release          BROWN          (-)          AT SWITCH
               ALSO FOUND AT SJB, PIN 28 OF 26-PIN GRAY PLUG
turbobuick1
Member - Posts: 18
Posted: January 17, 2010 at 10:17 AM / IP Logged
Thanks for the help, but for the tachometer wire under the remote start section above, what does "uncommon wire" at fuel injectors mean? Is this a typo? Does it mean the common positive wire for the fuel injectors? Or is there a better place to source the needed tachometer feed for the remote start? On the wiring diagram that came with my Compustar system, it says for that lead "Engine Sensing Input (Alt./Tach/Battery)"
I'm installing a Compustar FT-6200S Controller or "Brain".
tedmond
Gold - Posts: 4,610
Posted: January 17, 2010 at 10:25 AM / IP Logged
uncommon wire means at each injector, there will be similar colours for all of them. using the uncommon one or "differant" will work.
Ted
Compustar Expert
turbobuick1
Member - Posts: 18
Posted: January 17, 2010 at 12:23 PM / IP Logged
On this 2.0L engine, all four injectors have two wires each. They all share a common BLUE power wire, and what you are saying is that I need to tap into one of the other wires (injector 1 has a GRN/BLU, injector 2 has a GRN/YEL, injector 3 has a VIO/GRY, injector 4 has a YEL/ORG). So I tap into one of these 4 wires correct?
Thanks for your help, I really appreciate it guys! This is only my second remote starter install and I just want to make sure I do it right the first time around. I wouldn't be surprised if I have a few more questions for you guys this afternoon.
chev104275
Gold - Posts: 1,436
Posted: January 17, 2010 at 2:57 PM / IP Logged
yes you can use any of the wires that are not blue that you listed
turbobuick1
Member - Posts: 18
Posted: January 17, 2010 at 4:57 PM / IP Logged
Thanks for the verification. One last wire to hookup and then I can start testing the remote starter out.
My last wire is on the Bypass Module (in this case a Fortin Key-Override-SL2.) It's a BLUE wire that is supposed to be connected to a wire on the remote starter; and I don't know which one. The label for this wire is "(-) While Running" and it is a input to the bypass module. Here are my choices on the remote starter:
1) (-) 250mA 2nd starter output
2) (-) 250mA 2nd ignition output
3) (-) 250mA 2nd accessory output
4) (-) 250mA Status Out(GWR)
5) (-) 250mA Rearm output
6) (-) 250mA Disarm output
7) (-) 250mA Horn Output
8) (-) 250mA Aux1 Output
By the way, I left a few out that in my mind there was no way it could be them.
So the big question is, which one is it??
mikvot
Gold - Posts: 1,043
Posted: January 17, 2010 at 5:05 PM / IP Logged
#4
chev104275
Gold - Posts: 1,436
Posted: January 17, 2010 at 5:07 PM / IP Logged
number 4
turbobuick1
Member - Posts: 18
Posted: January 17, 2010 at 5:11 PM / IP Logged
Sweet, I'm running out to the garage to hook it up!
Page of 3
Tuesday, January 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
