2004 Dodge Caravan headliner
masterchief
Posted: January 22, 2004 at 8:51 PM / IP Logged
Hello all, great discussion group ya got going here.
  I just bought a new Dodge Caravan and want to install an overhead flip-down monitor.  Where can I find specific instructions (with pics) on how to get the headliner down to install the monitor and cabling and get the headliner back up like new?  Website?  Magazine article?  Dodge factory manual?   Does the headliner need to come out to do all this work, or is there a way to do it without dropping it?  What about the cable routing, down the door pillar or next to the windshield?
  The electronics and wiring is no problem for me, did it my whole career in the Navy.  I'm just a little apprehensive about tearing into my new interior without knowing how to avoid damage.
auex
Platinum - Posts: 5,041
Posted: January 22, 2004 at 9:15 PM / IP Logged
I found this "how to" quickly. It looks to be close to the steps that you would need to take, depending on what monitor you purchase. Here you go.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
geepherder
Platinum - Posts: 3,668
Posted: January 22, 2004 at 10:07 PM / IP Logged
Hey Master Chief,
ET?  I was an RM until it was changed to IT.  Joining the Corps now though.  I've never removed a headliner to install an overhead.  You can use the cardboard box it came in to make a template.  Trace that exactly where you want it.  Cut it out (razors can go dull quick, so have spares handy) and screw some 1/2 inch MDF into the overhead braces to mount the screen.  You can run your lines up the b-pillar, and flex the headliner just enough to feed the wires over.  Pop your panels back in place, and push the weather stripping back, and you should be fine.
masterchief
Posted: January 23, 2004 at 3:26 PM / IP Logged
Thanks auex and geepherder, good information.  After seeing the procedure that auex linked I guess I may not have to drop the whole headliner.......but, I don't have a dome light or overhead console behind the front seats.  Because of that, I'm not sure where the braces/brackets would be hiding up there that I could mount the flip down monitor to.  Is there a double layer of sheet metal above the headliner?  I definitely like the idea of leaving the headliner in place for the install, but I'm not sure where I should cut through the headliner.  Does anyone know where I can see a pic of the roof sheetmetal layout in the 2004 Dodge Caravan to know what's up there?
geep, nope, not an ET, a Fire Controlman for all of my 22 plus years.  What did you mean by MDF?
NowYaKnow
Gold - Posts: 1,217
Posted: January 23, 2004 at 6:37 PM / IP Logged
WARNING: I'm going to write a book here so you'll have to deal with a lot of reading...
Unfortunately not all cars have a domelight or anything in the rear roof to help guide you. Look around for any push clips in the headliner. 99% of the time these pushclips go directly into a support beam.
As far as mounting if possible you will always get a much more solid mount if you can hit a factory roof beam, but if not there are options. When no beam is useable, I like to use 1/2 or 3/4 wood (MDF = medium density fiberboard) attached to the headliner itself. The downside to this is the stiffness of headliners and some cars hanging a TV from the headliner alone won't even work..They just bounce around too much to even be able to watch.
In your case I'm going to say that hanging from the headliner should be fine assuming your not installing a monster tv. I've done a bunch of caravans in the past, but honestly it's been too long to remember just how I ended up mounting it..
A couple tips on where to position the tv:
1. Take the mounting shroud for your tv and place it up against the headliner. If there is a flat spot that would be ideal. Otherwise you have to cut the shroud to match the contour of the headliner which can be a pain.
2. Mount the tv to the shroud and hold it up in what you think is a good spot..Sit back in the seat and flip the screen down..Is it too close to your face? Too far away? Remember most times kids will be watching it so they will be further down in the seats. You want to find a good spot in the middle like I said right in your face is no good and too far front is no good.
3. Now go sit in the front seat and see if the position interferes at all. If so you definately have it too far front. Hitting your head on the screen while driving is no good..
That's it..Once you are pretty set on the position of the tv take a pick tool or an awl and push up (just enough for the headliner to be marked!) through the mounting holes of the tv to mark the headliner.
At the same time you may want to take some masking tape and put a couple pieces around the perimeter of the shroud. This way you know just how much headliner you can cut away and the shroud will still cover it.
Once that's done take a FRESH razor blade and carefully cut out a small section of the headliner. I usually cut a small rectangle out around the sections I marked with the awl. Feel up there for any wiring that may be running.
If it's clear you can cut a larger hole until you have something big enough to work with. At this point it will be very easy to tell if you can hit a beam or will have to use a piece of wood.
Now before you do anything else at this point I would run your wiring. Again every car is different when it comes to running wires. You have to sort of feel out the headliner to see which way will be the easiest. Some common options:
1. Run wiring from the hole you cut to the front of the windshield by the rear view mirror. Then go left or right and down the a-pillar.
2. Run wiring from the hole you cut 90 degree left or right to the side of the van. Bring the wiring down the side b-pilllar then up to the front or bring the wiring forward along the headliner and down the a-pillar.
3. Run wiring from the hole you cut at about a 45 degree angle to the side of the headliner and down the a-pillar. (This is the most common for me)
Now back to mounting..Some tips for using wood:
1. Obviously the bigger the piece of wood you can stuff up there, the more surface area of the headliner it uses, the more the weight distribution is spread out. This means less bouncing around for the tv.
2. Once you get the wood up there put a couple small screws through the headliner and into the wood to keep it in place. Nothing worse than trying to screw a tv to a piece of wood that is moving all around on you.
3. Once again hold your tv and shroud up to the roof, center it, and use your awl to mark the wood itself. Pull down the tv and start a couple screws on the marks you made. This makes it much easier in the long run.
Some tips for screwing into a beam:
1. Most beams have at least a few holes already drilled in them. These holes will almost always be to big or not in a spot that helps you any. Take your awl and stick it through one of the holes slowlyuntil you hit the roof itself. This gives you an idea of how much room you have to screw in. In most cases there is very little clearance between the beams and the actual roof.
2. Use the awl method earlier and hold the tv up to the roof. Using your awl through the tv's mounting holes, mark a few spots on the beam. Now take a 1/8" or so drill bit and predrill the holes. Remember how much clearance you had earlier? Drill slowly so you don't go through the roof when it finally goes through.
Ok now your finally ready to screw the tv up. One of the most crucial parts of installing a tv is selecting the right size screw. Too long and your gonna go through the roof, too short and you'll spend a lot of time trying to figure out why your screw isn't catching.
I start out with 1 screw that is obviously longer than I need, and screw 1 side up just a few threads. Don't hold the tv up there and try to line it up with your holes. If your gonna put a screw in the left side in first, sit on the right side of the vehicle and guide your screw into the hole. Much easier than trying to look up through the mounting holes of the tv and line it up. At this point the tv will hold itself up and you can give your hands and head a rest as holding the tv is awkward and tiring after a while. (Which reminds me of another tip using your head to hold the tv up against the roof to adjust yourself or pick up the screw that you dropped for the 5th time..)
NOW you can push the tv up against and see how your other holes are lining up. Just remember to take out the first longer screw and put something shorter in later. For all of this use a hand screwdriver and not a drill. As mentioned over and over there isn't a whole lot of room between the headliner and the roof or the beam and the roof.
And to answer your other questions there is not a double layer of sheet metal above the headliner..There is the headliner, and the roof itself. Not a whole lot going on up there..
Also as mentioned by others dropping the headliner isn't necessary. We install a lot of the factory ford kits and they require that you drop the headliner in order to get their brackets in place..Not TOO hard just time consuming and you have to be very careful. For your normal universal tv I wouldn't even think about dropping the headliner..Oh well there's a bunch to read hope some of the tips can help you out. Take your time and use your head and you should be fine!
Here is 2 quick pics:
http://www.installz.com/installpics/tv1.jpg
First one gives you an idea of what I meant when I mentioned cutting the shroud to match the contour of the headliner. (Town & Country van)
http://www.installz.com/installpics/tv2.jpg
Pic 2 shows a tv mounted in a Town & Country van. You can see a factory push clip right near the tv which really helps give it support since it is just supported by the wood on the headliner method.
Good luck,
Mike
auex
Posted: January 24, 2004 at 12:29 AM / IP Logged
Pic 1 as stated above
Pic 2 as stated above
masterchief
Posted: January 24, 2004 at 8:30 AM / IP Logged
Mike,
   Nothing but great information, and I truly appreciate it.  Those will help immensely.  I've already printed out the tips.........hope I'm not breaking any copyrights!!!  2004 Dodge Caravan headliner -- posted image.
   Thanks to everyone on here.  Now I've gotta start shopping for the right monitor.
Marshall
securinu
Silver - Posts: 772
Posted: January 25, 2004 at 12:04 AM / IP Logged
we carry Magnadyne which has a custom shroud you dont need to cut.
http://www.magnadyne.com/index.cfm?MasterAction=Item&InvMasID=7649&Web_Catid=255
Joe O'Byrne
Owner / Installer
NowYaKnow
Gold - Posts: 1,217
Posted: January 25, 2004 at 2:06 AM / IP Logged
Almost forgot to mention a custom kit would be a good option as well. We do a lot of the magnadyne universal stuff and would highly recommend their products. Only complaint is there shrouds are thick and if you don't get a custom cut one you will need probably a jig saw to cut the contour where most others you can get away with a razor blade. Nice screens and I have yet to see any of the ones we installed come back. Can't say the same for the audiovox (so-so) and the rosen (JUNK) that we put in.
Either way good luck with your search hope it turns out well! Feel free to post any other questions you have along the way. Good luck,
Mike
ragnampizer
Member - Posts: 14
Posted: February 06, 2004 at 12:07 AM / IP Logged
well i have a 96  and i am gonna try this , i will let u guys know how it turns out, thank you
making it work
