Posted: December 06, 2005 at 8:32 PM / IP Logged
Posted: December 06, 2005 at 8:35 PM / IP Logged
Posted: December 06, 2005 at 8:44 PM / IP Logged
Posted: December 06, 2005 at 9:01 PM / IP Logged
Posted: December 06, 2005 at 9:04 PM / IP Logged
Posted: December 06, 2005 at 9:37 PM / IP Logged
Posted: December 06, 2005 at 11:14 PM / IP Logged
Posted: December 06, 2005 at 11:57 PM / IP Logged
Posted: December 07, 2005 at 12:03 AM / IP Logged
Posted: December 07, 2005 at 12:05 AM / IP Logged
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
I have a Paladin wire stripper similar to this one, it's self adjusting, which is handy. It can separate the insulation by pushing it apart after cutting it, without having to remove a notch section.
I've used a Klein of the type that auex showed above, and it's good for heavy gauge wires, but it is kinda clumsy under the dash in a nest of wires, because you have to make sure you place it in the right notch for it to work properly, and it has to have enough side clearance from all the other wires in the bundle.
