running power wire in ford focus
joescutlass
Posted: December 19, 2007 at 10:40 PM / IP Logged
where is a good place to come through the firewall in a 2000 ford focus se wagon .
i am running 4 awg power wire
if its too loud you must be too old
techman93
Silver - Posts: 591
Posted: December 20, 2007 at 10:46 PM / IP Logged
I just did a 2006 Ford Focus and found a plastic plate to left of steering column on firewall. If the 2000 has one I am sure you probably could drill a hole and run 4 awg through a plastic grommet.
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
gus1
Gold - Posts: 1,013
Posted: January 06, 2008 at 8:14 PM / IP Logged
Look at the firewall to the left of the brake pedal (inside the car). You will see a knockout in the insulation, peel that out, and there is a plastic grommet you can drill through there. This is assuming an automatic transmission, as that is where the clutch pedal goes on the 5 spd cars.
Friday, January 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
