cap or battery?
cavabenzo
Member - Posts: 9
Posted: December 23, 2007 at 12:28 PM / IP Logged
So help me out here I was always told you need a cap til recently I mentioned to someone they would need a big one for the gear he was gonna run at least a 10 farad I said and reading the post most of you guys left up your saying the same thing i was told they don't recover fast enough to fully charge cuz their too big I was told to get no bigger than a 2 farad but according to some of you guys 1 farad is not that great either so my question is if I used a Drycell deepcycle battery and maybe a bigger gauge wire from the alternator to the starter would that be better even though i always had 2 optimas in my car?
cap or battery? -- posted image.
Gotta be all business Foolishness is for the weak
Alpine Guy
Platinum - Posts: 2,478
Posted: December 23, 2007 at 1:17 PM / IP Logged
Neither is better, battery's and capacitors store power, alternators MAKE power, if your adding accessories such as amps you need a larger alternator to supply that power. Once you have a good alternator set up you can then get a capacitor to slightly and I mean slighty smooth out the current. And additional battery's are only useful if you are running your stereo with your car off for extended periods.
aznboi3644
Gold - Posts: 2,600
Posted: December 23, 2007 at 1:34 PM / IP Logged
upgrade your big three with atleast 4 gauge wiring first
cavabenzo
Member - Posts: 9
Posted: December 23, 2007 at 1:41 PM / IP Logged
That makes sense but I do usually run the stereo when the car is off mostly watching movies or playstation, lasts bout 1 1/2 to 2 hours before I need to start the car so your help is much appreciated. So a 150 - 200 amp alternator should be just fine with a 2 farad cap?
cavabenzo
Member - Posts: 9
Posted: December 23, 2007 at 1:46 PM / IP Logged
I am running 0 gauge from the Batteries and the grounds to 4 gauge to the amps and cap what else should be bigger?
aznboi3644
Gold - Posts: 2,600
Posted: December 23, 2007 at 4:08 PM / IP Logged
have you upgraded your big three???
A cap isn't needed if you have a sufficient alternator
cavabenzo
Member - Posts: 9
Posted: December 23, 2007 at 5:51 PM / IP Logged
not all of them still gotta do the alternator to battery and block to chassis
Alpine Guy
Posted: December 23, 2007 at 7:16 PM / IP Logged
What car? What amps are you using, and what are their fuse ratings?
I would for sure start with an alternator upgrade, and also wire a low voltage shut off switch so when your battery gets low, your stereo will shut off. You can wire that into the ignition wire for your cd player only. Thats for when your letting it play when the vehicle is off.
cavabenzo
Member - Posts: 9
Posted: December 23, 2007 at 8:29 PM / IP Logged
4000 WATT Lanzar 2 ch amp 2 35 amp fuses, 1000 WATT  Lanzar 4 ch amp 2 20 amp fuses and its the Cavalier in the picture and where can i get the switch?
audiocableguy
Copper - Posts: 630
Posted: December 23, 2007 at 11:00 PM / IP Logged
"4000 WATT Lanzar 2 ch amp 2 35 amp fuses",
Something tells me with 70 Amps worth of fusing that amp is no where near 4000W. Lanzar!
