2005 taurus after market keyless entry
danboy
Posted: December 26, 2007 at 11:09 PM / IP Logged
I am trying to intall a keyless entry on a 2005 taurus. It was a hertz car and did not come with factory system. I checked to see if it had factory setup by cycleing the key on off six times. It did not respond with the locking of the doors. I got a system to work but not all the time. I read on this site that my gem goes to sleep after a few minutes and won't let the keyless work properly. I tried putting my car in program mode to turn this off but I can't make it work I tried door closed and door open. When I get to the part where the horn honks I don't get a honk. Anyone have some ideas how to make this work. I also read somewhere the car has factory keyless if it has sticker that reads A-1 on the driver door post between the hindges. Mine has the sticker but will not program for remotes. Any ideas Dan
another-kelly
Silver - Posts: 618
Posted: December 26, 2007 at 11:32 PM / IP Logged
if the aftermarket unit has it, connect the domelight supervision.
tedmond
Gold - Posts: 4,610
Posted: December 27, 2007 at 8:04 AM / IP Logged
you will have to pulse the BCM to wake it up. after 10 min or so, the BCM goes to a sleep mode to conserve battery life. as kelly mentioned, connecting a domelight should pulse the BCM to wake up, then u can unlock or lock since domelight comes on first before unlock occurs.
mikvot
Gold - Posts: 1,043
Posted: December 27, 2007 at 5:04 PM / IP Logged
