2007 328xi, compustar cm4200
fdny136
Member - Posts: 30
Posted: December 31, 2007 at 11:33 AM / IP Logged
installing a compustar cm4200 with cansl2 and int-bmw1 in a 2007 bmw 328xi this week.anyone have any tips or knowledge? this is the recommended setup as far as I can tell but few have been done.I have searched for wire colors and locations but have found none.it is a personal vehicle I put together so please do not tell me to go to the dealer or warranty etc,as it does not apply here.I am very familiar with the dei products ,programming etc ie: no engine checking.do you know which harness or wire are absolutely nessasary on the compustar? I am using the data bus cable between the remote start and the modules.can the modules be wire in line via databuus? any help appreciated .
Platinum - Posts: 12,488
Posted: December 31, 2007 at 1:02 PM / IP Logged
Only the power harness on the module is RS232 is via data. All the outputs and inputs on the CANSL2 need hard wiring for the BMW. Very basic installation especially with the CANSL2 doing 75 % of the installation. The required connections are all the ones on CN1 harness.
2007 BMW 3 Series Note(s): Firmware 10.0 or newer with INT-BMW1 required
fdny136
Member - Posts: 30
Posted: December 31, 2007 at 3:00 PM / IP Logged
thanks very much for the reply.would you happen to have wire colors and locations for the 2007 328xi,I have not been able to find them thanks again
fdny136
Member - Posts: 30
Posted: January 01, 2008 at 3:37 PM / IP Logged
all installed this am ,but not without any glitches.programmed the remote , cleaned up some wiring.door locks trunk etc all work well , car cranks but will not start.I believe it has to do with the can-sl2 .I tried the programming sequence a number of times with no sucess also double checked my wiring ( no smart key so wound the wirs around key and tumblers.it appears its not learning the key? light on cansl2 just keeps flashing. any assistance woul be very helpful thanks
fdny136
Member - Posts: 30
Posted: January 01, 2008 at 7:15 PM / IP Logged
I now believe I may have a problem with the ign wire.does anyone know the wire color and if it needs to activate a second ign.sorry for the posts there is just very little wire info on this vehicle
fdny136
Member - Posts: 30
Posted: January 01, 2008 at 7:19 PM / IP Logged
looking for remote start  wire info for an install on this vehicle.I did a search but  did not find it almost done with the install of compustar 4200 bmw int and can sl2 but need to come up with correct ignition
Posted: January 01, 2008 at 7:48 PM / IP Logged
IGN #1 - GREEN
IGN #2 - VIOLET
Posted: January 01, 2008 at 7:49 PM / IP Logged
Leave key in the ignition and see if vehicle stays running after remote start. If it does then it's the immobilizer bypass that is not working or installed properly.
fdny136
Member - Posts: 30
Posted: January 02, 2008 at 9:52 AM / IP Logged
you are correct  ,I too believe it is the bypass.I have double checked the diagrams supplied by fortin for the cansl2 and bmwint1 and all appears correct on the compustar I used the cn1 and all is connected eexcept the blue slectable + .
fdny136
Member - Posts: 30
Posted: January 02, 2008 at 11:59 AM / IP Logged
unable to locate the violet
