2000 cavalier vss
swire2
Posted: December 31, 2007 at 5:10 PM / IP Logged
I am in the process of installing the new JVC nav unit and I can not find the VSS wire to connect to the unit. From what I have read it should be dark green and white. The only green and white wire I found gave me a constant speed of 5mph even when I was parked. Any help on locating the proper wire would be greatly appreciated.
extreme1
Silver - Posts: 1,070
Posted: December 31, 2007 at 9:01 PM / IP Logged
pin 34, blue connector at ECM, passenger side of engine compartment
Shaughn Murley
Visions Electronics
Red Deer, Alberta
sparkie
Platinum - Posts: 2,061
Posted: January 01, 2008 at 6:51 PM / IP Logged
The wire is easiest to get to at the connector plug beside the driver's side shock tower. It is the large connector between the air filter box and the firewall. The VSS wire is the dark GREEN / WHITE near the front driver's side corner of the plug. The wire is only on the bottom side of the plug and stops there. It does not come through the top of the plug.
sparky
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
