how to reset passlock
opj38
Member - Posts: 31
Posted: January 02, 2008 at 7:47 AM / IP Logged
Does anybody know how to reset the passlock 2 . car wont turn over.
KarTuneMan
Platinum - Posts: 7,056
Posted: January 02, 2008 at 8:24 AM / IP Logged
turn the key to run....leave it for about 10 min.
Why did it all of a sudden quit working? Are you attempting a remote start?
You might want to give a little more info here.
Look here for some more info.
opj38
Member - Posts: 31
Posted: January 02, 2008 at 9:26 AM / IP Logged
yes trying to install remote, was checking the resistence value to bypass and started the car by mistake. 2006 saturn Ion. passlock 2 next generaton.
tedmond
Gold - Posts: 4,610
Posted: January 02, 2008 at 10:01 AM / IP Logged
your suppose to start then cut and measure the resistance
RESET
turn key to run
open driver door and leave it open
come back in 10 min and the light will be gone, try to start with key, if it doesn towrk, leave it for another 10.
opj38
Member - Posts: 31
Posted: January 02, 2008 at 10:09 AM / IP Logged
Thanks for the reply, will give it a try.
opj38
Member - Posts: 31
Posted: January 02, 2008 at 11:53 AM / IP Logged
RESET
turn key to run
i ve noticed that when key turns to start position all lights shut off it wont even crank.
when key turns to start position security light comes for a while then goes
thanks for all helping me
opj38
Member - Posts: 31
Posted: January 02, 2008 at 2:07 PM / IP Logged
thanks aal the guys in this forum
finaally find the problem 2 amp fuse [ign fuse]was blown in fuse box located drivers side panel
changed fuse it starts rightway
