08 corolla , cm4000 compustar
jbody
Member - Posts: 35
Posted: January 07, 2008 at 7:47 PM / IP Logged
As the title states, I have a Compustar Pro CM4000 unit.
components being used:
Compustar Pro 2W900PRO-AS
KEY-OVERRIDE-SL2 (ifar.ca) (bypass module)
now, compustar has a status output wire that I have connected to the bypass module, do I need to diode the same wire to connect the wire to the keysense wire on the vehicle as well. since the notes says "using the status output to trigger this wire during remote start will disarm the factory alarm without unlocking the doors."
so this is what i was originally going to do:
CM4000 status out to bypass module only.
bypass module keysense wire to keysense wire on vehicle.
should i be doing this rather.
put a diode on the status out wire so i can attach it to the keysense as well as put a diode on the wire for the bypass module for its keysense wire as well?
little bit confused at the moment.
any help would be appreciated it.
KarTuneMan
Platinum - Posts: 7,056
Posted: January 07, 2008 at 8:03 PM / IP Logged
That key sence appears to be an INPUT, not an OUTPUT. So that won't work. I would diode isolate and use the staus output.
jbody
Member - Posts: 35
Posted: January 07, 2008 at 8:12 PM / IP Logged
here's the notes.
Key Sense          BLUE/BLACK          (-)          IGNITION HARNESS
STATUS OUTPUT DURING REMOTE START WILL DISARM ALARM WITHOUT UNLOCKING DOORS
KarTuneMan
Posted: January 07, 2008 at 10:37 PM / IP Logged
Yes you do have it correct. I missread your post and thought you wanted to use the keysence on the CM4000 on the keysence of the car....08 corolla , cm4000 compustar - Last Post -- posted image.
jbody
Member - Posts: 35
Posted: January 07, 2008 at 10:39 PM / IP Logged
so what i should originally is fine?
or do i need to diode both the wires for the keysense.
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
